Yep it sounds good from that perspective. What I was wondering is whether having a bed that is effectively uneven (assuming the rear wheels remain on the dropped part) makes it hard to push on/adjust location/hold while tying down etc etc.
My trailer has 3 metre ramps
They are awesome for lowered cars
No need for the beaver tail when you have very long ramps
I assume these slide up the length of the trailer and just slide out into position?
I saw a dodgy pic in your thread but didn't show too much... Needs moar pics :P
I had to go bever tail, 2.4mtr ramps, 100mm drop axles and also welded on top of the trailer bed sections of boxed gal steel so the car sat higher. Also heavily modified the trailer wheel arches so I could open the doors when I put the car on the trailer.
The tilta trailer and Nevco are way more expensive but I can see the less hassle from them.
SO I ENDED UP GETTING A 14FT X 6.6 FT TRAILER WITH BEAVER TAIL AND TYER RACK AND WINCH POST - CAME WITH WHEELS (DONT LAUGH SOME PLACES CHARGE FOR THEM) AND A SPEAR AND JOCKEY WHEEL AND RAMPS SLIDE UNDER THE TRAILER - I PAID $3250 DRIVEAWAY WITH NSW REGO WAS ABOUT $3500 IM AT WORK BUT I WILL POST A PIC TONIGHT -
I HAVENT HAVE ALOT OF EXERIENCE WITH CAR TRAILERS BUT THIS IS SO FAR THE BEST I HAVE USED DRIVES VERY WELL I WAS IN PEAK HOUR TRAFFIC IN SYDNEY WHEN I GOT IT HARDLY NOTICED AND DIDNT SWAY AT ALL ON THE HIGHWAY FROM HOME - FROM MARIO TRAILERS IS WHERE I PURCHASED IT - THEY WERE CHEAPST BY 2-300.
TILTAS TO LOOK GO BUT GOTTA HAVE THAT TYPE OF CASH - I ONLY JUST BROUGHT IT HOME SO HAVNT PLAYED WITH IT YET BUT SO FAR SO GOOD
STOP YELLING :rant: lol
Those Mario trailers sure do look cheaper than most around, my missus spotted them a while back but after reading the guys advice above about steering clear of cheaper ebay spec trailers as long term they cause more hassle then they are worth, we decided to look locally and custom...
Post some pics so we can get a look ;)
I WILL !!!!!!!!!
sorry i work with caps on wasnt even watching lol
Mario trailers isnt ebay spec? if thats what you were saying,
like i said i havnt put the car on it at all yet but so far all signs are good - picks tonight
Lol
Not picking on Mario Trailers, just that we found them on ebay in the same price range as the others (Hence why i said ebay spec haha).... They may be better quality, i have never seen one and as you can see by me being in this thread, i have no farkin idea about trailers either lol
The reason i am worried about quality as its first real run is going to be from NSW --> SA --> VIC back to NSW for the SAU NATS!
Looking forward to more detail and feedback!
yeah same her i have no idea on spec as well -
i mainly focused on the top and the weights to make sure tow was safe ect - when it comes to breaks and things from what i read most ppl have different views -
but so far carless drive trailer was very good - and the rta i went to in sydney said they were getting customers from mario trailers every day -
ranging from car - camper to box ect - and the lady at marios said shed had 3 ppl from canberra enquire and 5 purchases - thats gotta be a good sign - soon as im home wil post some pics
Edited by Reese69
Lol
matt im in the same boat as you.
im looking at getting a trailer and first run is vic to sa then back!
im looking at going a tilt trailer with a hyraulic ram at the front so i can load unload my car anywere.
i hire a servo trailer atm and its so hard to get on and off, only certain places i can take it off and on.
yeah on that....servo trailers are almost always death traps. while you might use one to move something around town if you needed to, taking one on a long drive is likely to end in tears.
they are heavy, often have bent axles/bad alignment, cheap tyres, unmaintained hubs etc etc. I have seen some that are brand new which would probably be OK if you are lucky to get in before some other mug bends it, but most of them are terrible.
duncan, i hate using the servo trailer but ive had to in the past because lack of funds,
but now im going to buy a hydraulic ram tilta because servo trailers are 'death traps' as you put it.
what do people think of the hyraulic ram tilta trailers? i can get a brand new un painted tilta with the
ram and ramps and no lighting, half floor no sides, low guards, hydraulic brakes, 100mm drop axles for $2800 ?????
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
