This is Leesh's build thread. There is no qualitative goal here, as she already looks good. Leesh will simply be riding the wave of getting stronger and enjoying the benefits that come with that, at her own pace. Progress will be detailed here.
Leesh now @ 56kg
  • Like 2
https://www.sau.com.au/forums/topic/428501-project-anything-is-possible/
Flat Bench
25kg x10
30kg x10
30kg x10
35kg x 10
40kg x 1
Close Grip Lat Pulldown
30kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 10
50kg x 10
55kg x 5
Incline Press
20kg x 10
20kg x 10
22.5kg x 10
22.5kg x 10
25kg x 10
25kg x 10
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
Squats
20kg x 10
30kg x 10
30kg x 10
35kg x 10
40kg x 10
42.5kg x 10
45kg x 3 (failed on 4th)
Tricep Push Down (double pulley)
25kg x 10
25kg x 10
30kg x 10
30kg x 10
35kg x 10
35kg x 10
Captains Chair Knee Raises
10
10
10
10
10
13/07/13
Standing Shoulder Press
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 6
Seated Row
25kg x 10
25kg x 10
30kg x 10
35kg x 10
40kg x 8
40kg x 8
Decline Bench
30kg x 10
30kg x 10
35kg x 10
35kg x 10
40kg x 6
40kg x 6
Wide Grip Lat Pulldown
30kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 10
50kg x 10
55kg x 3
Deadlifts
40kg x 10
50kg x 10
50kg x 10
60kg x 10
60kg x 3
Bicep Curls
10kg x 10
10kg x 10
10kg x 10
10kg x 10
15kg x 10
15kg x 10
Aww shit Leesh has a build thread (courtesy of the Birdman :P)! Jesus, never really clicked to me when seeing your impressive numbers that you'd also be doing them in the volume of Birds' program. Well done, that's just another whole level of impressive :P
Keep it up.
Aww shit Leesh has a build thread (courtesy of the Birdman :P)! Jesus, never really clicked to me when seeing your impressive numbers that you'd also be doing them in the volume of Birds' program. Well done, that's just another whole level of impressive :PKeep it up.
Told you I lift ;)
Thanks for the support
BVT
Birds Volume Training!
  • Like 1
15/07/13
Flat Bench
25kg x 10
30kg x 10
35kg x 8
40kg x 3
42.5kg x 2
Squats
30kg x 10
35kg x 10
35kg x 10
40kg x 10
42.5kg x 10
45kg x 5
30kg x 10
40kg x 10
40kg x 10
50kg x 10
50kg x 10
55kg x 6
60kg x 1
Incline Press
20kg x 10
20kg x 10
22.5kg x 10
22.5kg x 10
25kg x 10
25kg x 10
30kg x 3
Tricep Pushdown (double pulley)
25kg x 10
25kg x 10
30kg x 10
30kg x 10
35kg x 10
35kg x 10
20
20
20
20
Birds and Leesh may have different views, but in the past, when I was doing multiple sets of 10, I found I was far leaner and more defined. This is not necessarily at the expense of strength either, just depends on how you train.
What's your main reason for more volume as apposed to more weight and less reps?
I'm thinking about giving this ago as I can't lift much due to a bung shoulder.
There's no scientific reason for it, I don't know enough about that lol. I've just always felt that volume training works well for maintaining a lean, athletic looking body and good mental / physical endurance (slow twitch fibers etc.). Seems to be less prone to injury due to less weight (no slip in technique, particularly training without a coach) and it also gives you a bit of a cardio workout at the same time, particularly with the compounds.
We use low rep / 1RM training at the end of the sets to introduce new weight when we feel we are ready to step up. To me this has always been about training to have more left in the tank no matter what you've been doing beforehand / how crap you feel. Again, no scientific basis, but I love training this way.
I have introduced it to a few people and the result is usually a decent amount of muscle and fat loss, even with an average diet. If you look up German Volume Training, some of the principles are similar, albeit with slightly less sets.
It's not the most efficient way to build strength, but I find it works fairly well on that part, too, as long as you're not looking to be a power lifter,
  • Like 1
It's more for getting the body to adapt better. I think it will help with pushing to the next level of strength and making those muscle fibres bigger. Drop sets, super-sets and pyramid sets seem to work for me :) I always make sure that I don't go light. High volume but keeping the reps lower I find helps me. Unless it's pure strength training, than 1-3 reps.
Leesh noticed this comment from Bulk Nutrients today during their lunchtime Q & A
When it comes to "bulking up with muscle" in regards to a female - ask any of our top female professionals on this very Facebook page how extremely DIFFICULT this is to do for a woman. It will not happen over night and it sure won't be the cause of a protein powder. Sure, carb and fat bulk can happen rapidly, as well as a heap of water build up, but in no way will muscle suddenly just appear on a female without some serious serious planning and dedication.
That is from Bulk in regards to a women asking about a powder that wont make her bulk up much, but I thought it was appropriate to some of the things you have said.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
