Flat Bench
25kg x 10
30kg x 10
35kg x 9
40kg x 4
42.5kg x 2
45kg x 0
Close Grip Lat Pulldown
30kg x 10
40kg x 10
50kg x 10
55kg x 8
60kg x 4
60kg x 4
Chin up x 1
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
Incline Press
20kg x 10
20kg x 10
25kg x 10
25kg x 10
30kg x 7
30kg x 7
Tricep Pushdown (double pulley)
25kg x 10
30kg x 10
35kg x 10
37.5kg x 10
40kg x 7
42.5kg x 3
42.5kg x 4
Captains Chair Leg Raises
20
20
10
10
10
Knee Raises
20
Couldn't do squats, rack was constantly busy then by the time it was free I didn't have enough time; will do tomorrow morning.
03/08/13
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 8
50kg x 3
55kg x 0
Deadlifts
40kg x 10
50kg x 10
60kg x 8
70kg x 2
Standing Shoulder Press
15kg x 10
15kg x 10
15kg x 10
20kg x 9
20kg x 8
Twinged shoulder, left 25kg for today.
Seated Row
25kg x 10
25kg x 10
30kg x 10
35kg x 10
40kg x 10
45kg x 8
Decline Bench
30kg x 10
30kg x 10
35kg x 10
35kg x 10
40kg x 10
45kg x 5
Wide Grip Lat Pulldown
35kg x 10
35kg x 10
45kg x 10
45kg x 10
55kg x 7
55kg x 5
Bicep Curls
10kg x 10
15kg x 10
15kg x 10
20kg x 4
20kg x 4
20kg x 3
Disappointed is an understatement but I've been averaging around 3 hours sleep a night for the past 13 nights, tried various things, hasn't helped so kinda at a loss as to what to do.
07/08/13
Flat Bench
25kg x 10
30kg x 10
35kg x 10
40kg x 3
42.5kg x 4
45kg x 1
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 4
55kg x 1
30kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 4
60kg x 4
60kg x 4
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
Incline Press
20kg x 10
20kg x 10
25kg x 10
25kg x 10
30kg x 4
30kg x 4
30kg x 4
25kg x 10
30kg x 10
35kg x 10
37.5kg x 10
40kg x 10
42.5kg x 7
45kg x 4
20
20
15
15
15
10
Knee Raises
20
Oh I'm sorry, did you say 45kg bench?
IS THAT WHAT YOU SAID?
Awwww YEAH
Did you have another rep in the tank? as you did 4x 42.5...
Maybe next session go from 35's straight to 45s and see what you've got.
BW BENCH HERE YOU COME!
  • Like 1
I know right so stoked! I did a second one but the spotter had to help me a bit at the end so I didn't count it :)
Also have a scapula/trapezius injury atm so once that's sorted I'm sure I can do better :)
Edited by L33SH
08/08/13
15kg x 10
15kg x 10
15kg x 10
20kg x 9
20kg x 8
Injured, no 25kg
Seated Row
25kg x 10
25kg x 10
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 3
Decline Bench
30kg x 10
30kg x 10
35kg x 10
35kg x 10
40kg x 10
45kg x 5
35kg x 10
35kg x 10
45kg x 10
45kg x 10
55kg x 8
55kg x 5
Bicep Curls
10kg x 10
15kg x 10
15kg x 10
20kg x 4
20kg x 4
20kg x 4
20kg x 3
Careful with the injury, I find sometimes I have to drop more than just most obvious exercise if something is sore as force is always translated through joints on the way to target areas in other exercises.
12/08/13
Flat Bench
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
30kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 5
60kg x 4
60kg x 4
65kg x 1
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
115kg x 5
Incline Press
20kg x 10
20kg x 10
25kg x 10
clicking in shoulder - stopped
25kg x 10
30kg x 10
35kg x 10
37.5kg x 10
40kg x 10
became painful - stopped
20
20
20
20
20
Knee Raises
20
I'm getting there, in a lot of pain today though. This injury is annoying me. The physio said it was a facet joint in vertebrae however I believe it's muscular lat or tricep. The pain is now localised to one area. Anyone have any ideas?
Edited by L33SH
If it's causing you that much grief you need to avoid any exercise inflaming it, see someone and only do motions that are working towards improving it.
Training on it will only prolong the recovery.
Then you have the wrong Physio. Personally I don't rate them much at all, the only reason I persist with the Physio for my ankle is it's not costing me anything and we're making slow progress.
I see my preferred Myo for everything else, a good therapist of any kind will tell you when they can't help you and recommend you on to the right person.
It's a slow process though and can be costly =\
Edited by ActionDan
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
