Leesh you are probably seeing things that aren't there.
My bet is you have improved and aren't the least bit backwards in appearence. I am sure people will be able to tell you this.
Hi Rev, mmmm I know what you're trying to say, but I have definitely lost definition.
11/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
60kg x 1
50kg x 5
Chin-ups
5
4
4
4
4
4
45 Leg Press
60kg x 10
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
115kg x 10
120kg x 5
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 7
27.5kg x 7
30kg x 3
30kg x 3
Bicep Curl
10kg x 10
15kg x 10
15kg x 10
20kg x 5
20kg x 4
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
16/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 6
55kg x 2
60kg x 1
50kg x 5
Bench Press
30kg x 10
35kg x 5
40kg x 1
45kg x 0
Chin-ups
6
5
4
4
4
5
45 Leg Press
80kg x 10
90kg x 10
100kg x 10
110kg x 10
120kg x 10
130kg x 5
140kg x 5
Hamstring Curl
20kg x 10
27.5kg x 10
30kg x 10
Physio gave me permission to do bench; my shoulder has to be permanently taped for 3 weeks though.
Go see a chiro that uses 'alternative' soft tissue methods. Not just a crack crack crack and on your way.
My wife has used one for years after being hit by a car and she talked me into going for some neck issues. I used to think it was a bit BS but there are some amazing techniques out there that work.
Something like this http://www.softtissuesolutions.com/art.html
We use http://chiropracticconnections.com.au/about-me in Bris. Highly recommended! Maybe send her an email and ask if she knows anyone over your way? It is a pretty small field...
Also re sleeping, maybe try Applied Kinesiology testing. Might find something, afterall it seems that you have tried everything 'mainstream' without much luck :)
As I said I first thought this stuff to be BS, but actually seeing it work is very interesting.
19/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 8
55kg x 2
60kg x 0
Bench Press
30kg x 10
35kg x 6
40kg x 2
45kg x 0
Chin-ups
7
6
5
4
4
4
45 Leg Press
80kg x 10
90kg x 10
100kg x 10
110kg x 10
120kg x 10
130kg x 6
140kg x 8
150kg x 5
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 8
27.5kg x 8
30kg x 5
30kg x 5
35kg x 1
Bicep Curl
10kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 3
20
20
20
20
20
Knee Raises
20
Ab Crunches
30
23/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 4
50kg x 4
55kg x 0
60kg x 0
40kg x 20
40kg x 10
Bench Press
25kg x 10
30kg x 10
35kg x 9
40kg x 2
45kg x 0
45 Leg Press
80kg x 10
90kg x 10
100kg x 10
110kg x 10
120kg x 10
130kg x 10
140kg x 9
150kg x 6
Chin-ups
7
7
6
5
4
4
Shoulder Press
10kg x 10
10kg x 10
15kg x 10
15kg x 10
20kg x 5
20kg x 6
Seated Row
20kg x 10
30kg x 10
35kg x 10
40kg x 10
45kg x 6
50kg x 5
55kg x 1
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 10
27.5kg x 10
30kg x 6
30kg x 6
35kg x 1
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 5
20kg x 3
20kg x 3
20
20
20
20
20
Knee Raises
20
Ab Crunches
50
