I would like to say that until I increase my weights I can't be sure that my knee bending in problem will subside, but I hope it does!
Let's not forget I have also changed my squat routine to lower weight, more volume on the advice from Birds, to increase my mobility. Birds puts alot of thought into my training and I probably don't thank him enough for this.
Thanks Rev for your recommendation, thanks Birds for your advice, training guidance and careful thought to my training. Thanks to Dan, Mitch and everyone else for reading this thread, supporting and encouraging me, and helping me when necessary. x
  • Like 1
21/10/13
Deadlift
50kg x 10
60kg x 10
70kg x 9
85kg x 1
95kg x 1
Bench Press
30kg x 10
35kg x 10
40kg x 5
40kg x 5
45kg x 1
45 Leg Press
80kg x 10
100kg x 10
120kg x 10
140kg x 10
160kg x 10
180kg x 3
Captains Chair
30
25
20
20
25
Knee Raises
20
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 4
20kg x 4
Ab Crunches
50
50
30
55 min boxing @ 610 calories
23/10/13
Squat
35kg x 10
40kg x 10
45kg x 10
50kg x 5
50kg x 5
55kg x 5
60kg x 2
Pause Squat
35kg x 10
40kg x 5
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 8
55kg x 6
60kg x 5
Shoulder Press
15kg x 10
15kg x 10
15kg x 10
20kg x 5
20kg x 7
20kg x 6
25kg x 3
25kg x 1
Seated Row
30kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 5
55kg x 4
Ab Crunches
100
They are feeling easier, however I really have to think about the movement and concentrate, as soon as I don't my knee bends in like crazy, it did bend in a few times tonight on the 55kg hence low reps
The more you practice the hip motion ,you wont need to concentrate as much. You need to keep that in mind for a while but, you are doing more weight now. Give it some time , getting the hips to work powerfully is like anything in terms of practice.
25/10/13
Deadlift
50kg x 10
60kg x 10
70kg x 10
90kg x 1
100kg x 1
Bench Press
35kg x 10
40kg x 5
40kg x 4
40kg x 4
45kg x 3
45 Leg Press
80kg x 10
100kg x 10
120kg x 10
140kg x 10
160kg x 10
180kg x 5
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 6
20kg x 4
Edited by L33SH
26/10/13
Squat
35kg x 10
40kg x 10
45kg x 10
50kg x 5
50kg x 6
55kg x 2
60kg x 0
Pause Squat
35kg x 10
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 8
60kg x 5
Shoulder Press
15kg x 10
15kg x 10
15kg x 10
20kg x 9
20kg x 7
25kg x 3
25kg x 1
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 4
55kg x 4
No matter what days I do exercises on, Saturday's workout is always shit, I'm so exhausted, and the bad sessions f**k with my confidence.
I would rather use the Saturday session to do assistance exercises such as bulgarian lunges, dips, hamstring curl etc but trainer says no.
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
