58kg
Pulled 122.5kg deadlift at 59kg
That's equivalent to you picking 2 of yourself up off the floor!
What people don't understand is how much easier life is to live when you are that strong to your own weight ratio you can do everything so much easier and go looking for heavy shit to pickup[emoji23]
Yep. I can easily lift things at work that the other females can't/won't.
Besides the physical positives, I feel happier within myself; I'm proud of my commitment and my mental strength!
  • Like 1
It's also quite healing; I had chronic back problems before deadlifts. Now fixed. Takes the pressure off the spine when the muscles and posture are doing what they are supposed to!
  • Like 1
Unfortunately I can't say the same, but maybe one day!
You will, yours is a bit of a different injury...the important thing is you're able to lift something and are doing it.
  • Like 2
  • 1 month later...
I'm back, starting again slowly and working my way back up
09/05/16
Squat
20kg x 10
40kg x 10
50kg x 15
50kg x 10
45kg x 10
45kg x 10
40kg x 15
40kg x 10
Pull-Up
6
5
5
Captain's Chair
35
25
20
Lat Pulldown
30kg x 10
35kg x 10
40kg x 10
Good to see you back. :)
Thanks, away on holidays, got sick then injured my shoulder!
My focus from now on is not so much strength, more endurance style training. A couple of reasons for this; mainly though as I have a long term lower back injury due to the discs in my spine being too close together from lifting too heavy for too long with incorrect form. I've found that lighter weight aggravates this pain less, so you're going to be seeing lighter weights but more reps... I'm hoping this will give me more of a hypertrophy look as well, maybe Birds can jump in here as I'm not actually sure!
  • Like 1
It's rehab with lighter weights; her injuries seem to respond better and deadlift and squat technique has improved a lot since doing the reset. The other reason is to give the body and muscles a rest and a different rep range to work with. I've done a couple of resets myself using high rep sets of low weight and, building up the weight each week, when I return to the lower rep weights I can knock out a few more than I used to.
  • Like 2
12/05/16
Bench Press
30kg x 10
40kg x 10
45kg x 5
40kg x 9
40kg x 10
40kg x 10
40kg x 10
Bicep Curl
20kg x 10
22.5kg x 6
20kg x 10
20kg x 10
20kg x 10
20kg x 10
15kg x 16
15kg x 10
Hamstring Curl
23kg x 10
30kg x 10
30kg x 10
30kg x 10
30kg x 7
30kg x 6
23kg x 15
  • Like 2
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
