Can't lift arm above head = possible supraspinatus inflammation too. Don't agree with physio recommending you do deads again next week just to test the waters for aggravation. Way too soon after injury.
Correct movement shouldn't cause any aggravation
25/11/13
Squat
35kg x 10
40kg x 15
45kg x 12
50kg x 5
50kg x 4
45kg x 10
45kg x 10
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 8
60kg x 5
55 min boxing @515 calories
Physio wants me to do my normal program this week to help her gauge what I should do next but I decided to not do seated row and shoulder press because too painful.
So if someone has a broken arm, correct movement should suffice?
No Birds, and that is a terrible example in relation to what the physio would be trying to achieve. Unless the muscle is torn substantially, carrying out a technically correct movement shouldn't do any damage. - having a debilitating tightness/impingement and tear are totally different.
see below.
Like with anything, the more information known, the easier diagnosis can be. This may be a trial and error over a few sessions to guage what is setting it off.
Someone like Rev going to see a professional, which he probably never needs to because of his knowledge, would be a lot easier to diagnose than the average person going in with no real probable cause.
With around 700 muscles, it's not as simple as saying 'my shoulder hurts'
*This isn't directed at you either Leesh, just had to explain my comment for birds as he got his back up over someone questioning him questioning a professional.
The problem is, jangles, that I have heard first hand how badly agonizing this pain actually is for Leesh - it is not a simple impingement or tightness that one can work through just to aggravate it for the sake of a physio. She literally can't lie on her back and cannot continue the movement (or many other movements for that matter) after doing a deadlift, can't lift arm above shoulder, struggles to dress and shower...which is very worrying for me...both as her partner and trainer...so you can forgive me for telling her not to do the exercise and to rest up, so that any part of the injury that can heal with time, does, and then her physio can safely look at diagnosis. The problem may not even be muscular, which is where my greatest concern is.
Rev is the first to say himself that, in the case of injuries, such as rotator impingement, cut out the *bro press* or exercise responsible for it, and start working on rehab and strengthening the supporting muscles while you rest.
As for professionals, there are all kinds, and professionals disagree with each other. But if you want to assign the label to someone you haven't met, be my guest. I have seen some great physios; I've seen some terrible ones who know absolutely nothing about weight training and simply take advantage of time healing wounds in most cases. I think it quite dangerous to assign utmost credibility to someone's advice simply because they have a certificate and an ultrasound machine.
Physio has already diagnoised my injury as joint rather than muscular - thorasic spine T5 to T8 is where I am most injured and intervertebral discs
Depending on outcome of next physio session, I'm looking at booking an appointment with a sports medicine doctor because I would like to continue gym as I've just signed up at a powerlifting gym for 6 months.
27/11/13
Bench Press
20kg x 10
30kg x 10
40kg x 5
40kg x 5
40kg x 5
45kg x 0
45 Leg Press
80kg x 10
100kg x 10
120kg x 10
140kg x 10
160kg x 10
180kg x 10
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 7
25kg x 1
Captains Chair
20
20
20
20
20
20
10
10
Knee Raises
20
Deadlift
60kg x 10
70kg x 5
70kg x 5
70kg x 5
80kg x 3
Ab crunches
200
Just taking it cautiously with my injury.
30/11/13
Squat
20kg x 10
40kg x 10
50kg x 10
45kg x 10
40kg x 25
40kg x 25
Pause Squat
35kg x 7
40kg x 5
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
65kg x 2
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 6
55kg x 5
Ab Crunches
250
30 min HIIT (grit strength)
10 min rowing machine
oh holy shit on the injury Leesh, that sucks! :( sounds a lot like some of the pains I was getting when I crushed my T5
Hi Troy, yeah probably very similar.. my injury is primarily T6 and T7
I took 3 panadol before physio yesterday and still had to get her to stop when she got to T6 :(
It's actually a bit less painful at the moment, hopefully I can sleep tonight... that's been the most annoying
02/12/13
Squat
20kg x 10
40kg x 10
50kg x 15
45kg x 20
45kg x 25
Pause Squat
40kg x 5
45kg x 1
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 7
65kg x 4
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 5
Ab Crunches
150
100
30 min core/ab class
(physio recommendation)
45 min boxing @ 350 calories
Goals are taking backward seat as I'm still having issues with bench, squat and deadlift. Really I'm just grateful I can still exercise at the moment. Trigger point today which will hopefully ease some discomfort.
Edited by L33SH
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
