My understanding was always that the knees come in when you're approaching your weight limit. You might have to do some assistance exercises or maybe some band work to help you at the problem point.
When do your knees start turning in? Coming up or going down?
I'm not savvy enough on squat mechanics to suggest which muscle you want to target, Rev would have a better idea, but I'm thinking anterior adductor (inner thigh) and ITB (outer quad) stability could be a problem?
I've used brackets just in case my terminology is wrong :)
Yeah it started doing it at 50kg last night which isn't that heavy for me, but yeah the 60kg was bad it was making my whole body lean to the left as I was coming up.
My knee is fine going down, it's as I come back up that it bends in and it's only the right knee, so therefore it's my left leg predominantly the adductor that is weak?
I was wondering if just doing leg extension, leg curls and lunges on the left leg would help at all
Left leg/glute is weaker than the right; right knee is coming in to save the day and you're shifting the weight over the right leg when the weight gets too heavy for the left to push it's share.
It's a mobility issue that needs to be trained out of the CNS, not unlike a dominant arm during bench press but more exacerbated. Your adductors aren't weak, you just don't know how to use them (or moreso, not use them) to keep the right leg from coming in to save the day when "shit hits the fan" and the left leg/glute can't drive anymore.
Interesting. Stuff, I'd say the right is compensating for the left.
EDIT: Birds just posted the same thing.
Anyway, you can do single leg work to bring the left up to par.
I had to do that back in the day of trying to get bench weight up. Trained left side to stop right compensating.
That or stick to a weight both legs can comfortably drive with and slowly increase weight until they are synchronized.
If used to do it on 40kg but now that she has surpassed that (making left leg stronger), it doesn't. It wasn't doing it on 50 recently but I'd say muscle tiredness is likely responsible for this particular incident.
01/05/14
Deadlift
60kg x 10
80kg x 5
100kg x 1
110kg x 1
80kg x 10
80kg x 10
Bench Press
20kg x 10
30kg x 5
40kg x 3
47.5kg x 1
40kg x 7
Bicep Curl
10kg x 10
15kg x 10
20kg x 5
20kg x 5
20kg x 3
Push-ups
20
Ab work
05/05/14
Squat
20kg x 10
40kg x 10
50kg x 5
60kg x 1
62.5kg x 1
50kg x 10
40kg x 10
40kg x 10
Pause Squat
40kg x 5
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 7
60kg x 3
65kg x 1
Seated Row (cable)
30kg x 10
35kg x 10
40kg x 10
45kg x 5
50kg x 4
55kg x 2
Captains Chair
40
30
30
09/05/14
Deadlift
60kg x 10
80kg x 5
100kg x 1
112.5kg x 1
90kg x 5
80kg x 10
80kg x 10
Bench Press
20kg x 10
30kg x 5
40kg x 3
50kg x 0
45kg x 2
40kg x 8
Bicep Curl
10kg x 10
15kg x 10
20kg x 5
20kg x 4
20kg x 4
Decline Ab Crunch with 5kg plate
10
10
10
Hanging Leg Raises
10
10
10
Pull-ups
2
12/05/14
Squat
20kg x 10
40kg x 10
50kg x 5
60kg x 0
60kg x 1
65kg x 1
50kg x 10
50kg x 5
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 7
60kg x 3
65kg x 1
Seated Row (cable)
30kg x 10
35kg x 10
40kg x 10
45kg x 5
Ab work
You women are all the same lol
Couldn't just say thanks, had to play it down.
Just accept the damn compliment :D
I did 25 reps of squat with a massive 25kgs on the weight belt last night and my back did not explode, awww yeah.
  • Like 1
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
