Unfortunately depression is something I know to well having struggled with it most of my life and yes I find it does make it quiet difficult to workout/function with it.
I'm having trouble with it myself at the moment and it shows up mostly in my workout, I'm not sure what to do about it either this is my third year trying to loose some fat and look/function "normal" and I'm yet to get my mind working with me.
I hope you find something that helps with it I'm looking at some group training sessions right now to force me to do my best maybe you should try the same?
I know exactly what you mean. I've been on and off for years. At the moment I am pretty depressed due to some recent personal stuff that's happened to me. I just don't know how to be okay again, and I feel like I have no one to talk to. The people that do know what I've been through tell me I need to move on and move forward, but I don't know how. I feel so lost, empty and at times numb. Sometimes I just have to block out my thoughts to even get through the day without crying and I know I'm repressing a lot of my feelings atm, which will probably f**k me up even more long term, but it's the only strategy I have.
Then I have other factors affecting me at this point in time; such as missing home/family/friends and missing my job back home which I really enjoyed.
Gym is really the only outlet I have here. I do enjoy group fitness classes and I used to do boxing, which I loved, but my injuries make it difficult for me to be able to do those things, so I just stick to weights which I know I can do relatively pain free.
  • Like 1
Few years ago i came really close to taking my life. Note was written and everything the only thing that stopped me was the thought of mum finding me after i did it and having to clean my room.
I learned that you can't bottle everything up and that sometimes real strength comes from asking for help from the right people and moving on from the wrong influences.
I am not sure what is going on with you miss leesh, sounds like you need a solid vent session with someone close to you whose thoughts and opinions mean something to you.
The day that i didnt go through with killing myself was the day that i woke up, started living and enjoying life and the moments we share with the people we have around us that truly care about us. Its also the moment that I said to myself that it could always be worse, if i am down in the dumps things can only get better and I'd never feel that way again.
Obviously i am know expert but i really hope that you can figure something out that helps you find some more enjoyment and release.
  • Like 1
One reason is that 75kg is not what I should be 1rming. Put my volume sets into a 1rm calculator and my 1rm comes out at nearly 100kg. Like I've said previously, I can squat 60kg for over 20 reps, so it's not a strength issue...yet I'm only just getting one rep of 75kg. I know it's a technique issue; I just don't know what I'm doing wrong with the heavier weight.
If you want , definately you can get there. But, the 1rm attempt on every workout isn't helping along with the volume. Not to knock the way you are working out as such ,you likely enjoy the volume. But, if you would like to notch up to the 100kg or so squat perhaps you might like to adopt a more suitable pure strength approach even if just for the squat only? You could do this just for the period till you hit the 100kg and then move back into the volume thing again once you get it.
75kg is pretty darn great though.
I feel much the same way.
Hi Rev, Leesh here
What's a pure strength approach? What would I do differently? No volume?
Take a powerlifting approach to the squat. If you would really love to hit 100kg for example. There is plenty of good info around to read over. Though remember you don't have to lift 100kg. Be clear about the 'values' something has to 'you' before you set out. The attempt could be a reward in itself? Or maybe it's not really worth the hassle? Do you squat for big quads or do you love being stronger ? Only you can answer that.
Looking at some basic ideas to implement , I would suggest ;
* Take some coaching from a power lifting trainer, even if just for the squat. Probably the best time and money spent to achieve the 100Kg in the best possible time. Squats are quite technical and it's a huge help having a coach through the lift to help improve . It's good for the pro's so it's good for anyone else. If 100kg is something that makes you feel excited then spending the cash on it could be a 'treat' to yourself. They can suggest some good changes to your program from actually observing you in the movement and also from what you have been doing. Beats the hell out of any suggestion I can make.
That aside some ideas I would suggest straight away;
* Don't do any more 1RM for 2-3months. 1RM are marginal for development vs risk as a constant training approach.
* Take a look at the technical aspects of the lift . Things like holding air in your belly when you lift (correct ab activation) etc.
* You can add some assistance movements. Abs are critical for lifts along with posterior chain, glutes and hips. The ab movements I was shown (a long time ago) are hanging leg raises (toes touch the bar/ or if too hard bend knees up to chest ( you should be showing the 'ass' so as to not make it a hip flexor movement) and/or standing cable pullovers (using lat pulldown & tricep rope)
* Box squats. These help sort technique out. Start at about 50% of your 1RM (37.5kg) . box of the right depth. The idea is to progress the weight each workout.
  • Like 1
29/04/15
Bench Press
25kg x 10
40kg x 5
50kg x 2
55kg x 1
50kg x 4
47.5kg x 5
47.5kg x 6
45kg x 7
40kg x 12
Deadlift
30kg x 10
45kg x 7
60kg x 10
65kg x 9
Bicep Curl
15kg x 10
17.5kg x 10
20kg x 10
25kg x 6
  • Like 1
Screen grab of Leesh during a pullups video
IMO some good shoulder and arm development on show
Definition also quite good considering Leesh is currently on a bit of a bulk to support strength and muscle development; at around 62kg, the heaviest she has been to my knowledge - also the healthiest looking IMO. Will be exciting times when she starts cutting, but we have a fair bit more strength and muscle to build until she's ready for that
  • Like 1
05/05/15
Bench Press
25kg x 10
40kg x 5
50kg x 2
56kg x 1
50kg x 5
50kg x 4
47.5kg x 6
45kg x 7
40kg x 13
Deadlift
30kg x 10
45kg x 10
60kg x 10
70kg x 7
Bicep Curl
15kg x 10
30kg x 5
22.5kg x 8
20kg x 10
20kg x 10
20kg x 8
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
