I haven't been to the gym, I can hardly drive let alone lift weights. I am resting, I didn't even go to yoga tonight. This isn't going to go away with rest.
Tried some foam rolling at home but now I'm in really bad pain when I move :( When I was foam rolling it really hurt on my shoulder blade and now it's just a constant tingling sensation on my shoulder blade with random shooting paim.. Good or bad?
It is going to go away with treatment & rest. Thats how you repair injuries.
Ice packs. Often as you can.
You can't foam roll and things till the inflamation is settled. As you discovered it just makes it worse sometimes.
You will get better.
I had another trigger point and massage session yesterday; went well. More physio booked for this week and ultrasound booked for next week. Doctor upped my anti inflammatory tablet dosage which I think has helped too.
I'll be back one day, just don't know when!
Thanks Rev :)
I have an anxiety disorder and exercise has always helped keep it under control. The last few weeks have been very difficult mentally but I've broken through mental barriers that I haven't been able to do for years, so I'm proud of myself in some ways at the moment. I'm getting my mental strength back :) physical will come next
Great work ! You should be very proud.
You must sometimes try to break things off that start to control you. You are proving that you don't need excersise to be who you are.
I am showing myself that nothing bad happens to me when I don't exercise, because that is what goes through my head. I'm now learning that my new exercise routine is going to be different and that's okay. I have an issue where things have to be 100% correct or I can't / don't want to do them. This is why I got so upset when I couldn't bench the bar without being in pain the other day. It's also why I'm not confident in deadlifts despite having coaching at PTC. Mentally, the last few weeks have been very difficult for me; some of my family and friends don't understand and think I'm being silly and dramatic. I'm really lucky Birds has been very understanding and supportive during this time.
I think I'm starting to see the light at the end of the tunnel :)
Edited by L33SH
good to hear Leesh,
hopefully your injury gets sorted sooner rather then later and even more importantly that you start gaining more control over yourself mentally. I've never suffered from anxiety but I did have a bad case of depression a few years ago, so I truly hope you continue down the positive and strong road.
good to hear Leesh,
Thank you :)
05/09/13
Squats
35kg x 10
40kg x 10
45kg x 5
45kg x 5
50kg x 1
55kg x 1
Chin-ups
3
3
3
45 Leg Press
40kg x 10
40kg x 10
50kg x 10
50kg x 10
60kg x 10
70kg x 10
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 10
27.5kg x 10
30kg x 5
30kg x 5
Bicep Curl
10kg x 10
15kg x 10
15kg x 10
20kg x 4
20kg x 4
20kg x 4
20kg x 4
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
  • Like 1
09/09/13
Dumbbell squats
15kg x 10
15kg x 10
15kg x 10
Squats
35kg x 10
40kg x 10
45kg x 5
45kg x 5
50kg x 2
55kg x 1
Chin-ups
3
3
3
3
2
2
45 Leg Press
40kg x 10
40kg x 10
50kg x 10
50kg x 10
60kg x 10
70kg x 10
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 10
27.5kg x 10
30kg x 5
30kg x 5
20
20
20
20
20
Knee Raises
20
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
