So it would seem that our Shell will be getting her Skyline back next week !!! :woot:
This Demands a Cruise in Her Honour and also to Blow a bit of High Octane Exhaust in Skippy's face as Punishment for taking her 34 off the road for soooooo long...
So how bout it Peeps?
I propose a meet at the Hindmarsh Bus Stop at 12pm ( for the late risers amongst us. ie. SHELL :) )
Leave around 12:30 - 1pm and go for a Respectful fang around some of our Favourite corners / scenery...
Uriarra - Cotter etc and perhaps finish up with BBQ Roadkill somewhere. (Pine Island?)
I am merely the instigator and will happily leave any or all Options / Changes / Better ideas to Shell herself to Update as she sees fit. (Date, Time, Location...whatever)
But yeah... We Should All Go For A Drive !!!
(and if the Shell 34 factor aint enough for you, it's my B'day next week too so just do it for me B!tches.) :P
aaaaaaand...GO!!!
https://www.sau.com.au/forums/topic/428518-cruise-for-the-shell-of-it-date-tba/
Oh thank god you didn't make it Saturday cos I have a massive piss up that work is paying for :D
Sunday I can do!
And it's your birthday Rob? Well, say no more! Lock it in Eddie!
Excellent!! That was Lucky...phewww... But you had / have the option to change at will anywho... :P
B'day is Thursdee... I'll be 83. :(
? :ph34r: ?
NoCanDoo - GTR off road
Ummmm... 34!?! Do it. Would be nice to see a few 34s crusin'. :D
Rosie, Shell, TokyoTaxi, Elle, Azathoth, B-Rice, The34T ???...
Would Be Awesome !!! Please???
Edit* Richard, I'll sell you an RB20 10psi Actuator and install it for you the day before... :whistling:
Thnx mate - doing the 34's cam cover seals, plugs, valley plate and 02 sensor on the Friday (19th)
Happy birthday too. Had mine on the 1st :D
:cheers: I have a Special Socket for the O2 if you need it. Didn't you do the plugs back when you snapped the old valley cover off?
and yes... I do owe you a Public H-B'day to you! (despite my 24hrs late Txt to you.) Sparkler > :merli: < Party Hat
I'm in.
Yaaay!!! :woot:
#@Trozzle bring your bike.
This^^^
keen to meet some people...im in
Awesome... You won't regret it. :)
i can't say no to rob, ill come out in the yaris if the gtr is not back lol
You can say No, but it goes on your permanent record. :P
post-78856-0-85399500-1373681535_thumb.jpg <<--- Something like this...
  • Like 1
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
