did you notice much in the wing etc? a mate runs the same wing on his 33 and he said he noticed a fair bit of difference
kay, i see 2 seconds, massive
Edited by Mr. Untouchable
OMG this car is a TV star...they had coverage of the Winton Supersprint on SBS/ Speedweek today. Well done :)
:cheers:
Nice work Johnny.....loving it.
Looking forward to seeing the latest additions!!
Have you had it on the scales since its diet??
Always wondered what they actually weigh......my rego sticker says 1200kg.....paha!!!
Cheers,
Dave M
Haven't yet.
They are much heavier than 1200, thats for sure. Nissan says 1370ish from the factory.
I'd say it's 1300'ish at the moment. You can take a heap off metal and gear off it, but there has been so much added.
So the focus is firmly on World Time Attack in October. Then Winton/Wakefield come up with feeder state rounds. So it's on to improve the car in readiness for the Vic round.
Weight, removing the AC
And ducting between the intercooler and radiator
Adding a power steering cooler at the same time.
Changing the spring rates from 8/6 to 10/7, longer wheel studs
A change in wheel size. From 17x9 +22 to 18x10 +35, these needed a 5mm spacer on the front to clear the inside.
Also, the regs for Vic were a little stuffed and allow club cars to run r comp tyres.
So a set of 265 A050's in medium, my first try at an r comp tyre.
more powerrrrrrrrrrrr
change the stock intake pipe to a hard one and give it more boost. Also had to change the actuator from the stock one to a HKS 1 bar.
The little 21U won't hold boost up top and bleeds off to from 18 to 15PSI
There isn't enough time for parts to come in a put the diff back together before NSW Time Attack, so I raid my brothers daily.
Which has a newer NISMO GT 1.5 way (mine is an old NISMO mech 2 way). But is a non ABS housing diff.
So I'll be running NSW TA without ABS :huh:
At the same time the rear arms go off to pedders for polly bushes and new ball joints.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
