sound deadener delete.
we also remove everything under the dash. though left the firewall heat shielding.
This stuff at the back was too hard to get too and I didnt have a heat gun. So I left it, will get back to it another day.
  • Like 1
next up, more lightening.
With the boot skin and hinges and lock gone. Bonnet pins now hold it all in place.
Best way to line up the holes on the bonnet, drill it from the inside...
Rear wiper motor and gear removed here as well and the radio antenna motor.
You can see the gurney fitting here and the bonnet pins in the boot. The oe lock hole was used to another bonnet pin on a bracket to hold everything down.
The gurney is just a piece of 10mm angled alloy from bunnings with slots cut in it allowing it to be bent into shape.
  • Like 1
This time around NSW are using the full WTAC rule book. so back to street tyres.
But! Yokohama don't have any 285 or 295's available.
So the only other option was Hankooks, z222.
In 285 they actually measure 295 and are huge on 18x10's. And Hankook be smoking as they are a 35 profile as well, very tall!
I'm working in Sydney at this stage (the day before nsw time attack). so my brother and dad are running around getting the car ready back in melbs.
i meet them in goulburn for the event.
cool. yep i removed that stuff too. and if you happen to go down that road of lexan, i saved 2.5kg each door, and about 4.5kg's in the rear screen. another 2.5kg's (each) in instrusion bars if you havent removed them, ofcourse if its still a regular streeter maybe leave them there. love the car mate, keep it up.
I've seen this car a few times at various events and I am absolutely astounded/impressed at your Winton time.
I'm not saying the car isn't well sorted, but I am definitely saying that is a crazy fast time for a car with the power this has. Which is a very good indicator of how good your driving is.
Clearly all that track time has payed off and I am going about my car the entirely wrong way!
Great build thread dude. I'll come and say hi the next time I see you at Winton/DECA.
I was thinking the same thing Dan, I'm always thinking the car is holding me back, which it probably is a little but not as much as my driving.
If John can cut those lap times with the set up and power he has then there is definitely room for improvement in my driving skills.
Great work John!
My new plan is to get my car running and then let John drive it and claim the lap time as my own...
Easiest time I'll ever cut from a PB :D
More than happy to. :yes:
Great work John!
There is always room for improvement, whether that is 0.2 seconds or 2 seconds. It's just chipping away and becoming more confident, having fun also helps!
rear seat/shelf sound deadening, fill plastic shopping bags with dry ice, race tape bags of ice into position leave for 10-15mins remove tape/bags and remove deadening with ease.
i haven't been able to get along to any days as yet this year, the progress on your car looks great!
After spending a cold few hours bashing it off the ground, tunnel and boot I was over it...lol
By the time someone told me about that method, the ice was gone.
Heat gun did an ok job, was actually present as it was freezing outside and nice and warm in the car with the heat gun.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
