  • 4 weeks later...
Finally put some time aside to re-plate the diff.
Looks as though it was setup with one less sprung plate either side and in it's place there was a geared plate.
So we've set it up the same way.
All being well the car will be running at the Family happy laps day at Sandown on the 21st.
  • 1 month later...
Haha yeh. It's addictive for sure!
Last event was just before XMAS, we had to change the diff again. On the day this time as the built one failed....
Bleh!
Have a weekends worth of work to get it up to scratch for the Time Attack season soon.
  • 3 months later...
Prep for NSW time attack and world time attack later in the year has started.
After chasing boost leak issues over the weekend at world time attack last year i decided to get some of the cooler piping re-done.
So Abe at Havoc fabed up a single peice section from the hot side to the cooler and re-worked the intake pipe.
However on the dyno at Chequered it still wasnt right. Trent and Abe found the inlet manifold gasket (the upper one) was leaking badly.
So changing that was fun...
Anyway, back into the doctors for a checkup with the new gasket.
And something else is a miss now...
The waste gate actuator is too stiff and boost control is non-existant. So that inlet gasket must have been leaking a little bit for over a year. As the the actuator held boost fine prevoisly.
Off with that actuator and on with a softer one.
Car made more power and torque on the same pressure. Awesome.
  • Like 1
The more I look, it seems very common to have boost leaks that we don't know about. Must be some good merit in pressurising the inlet to check for leaks.
The only way I could see to check for that one on the inlet manifold would be to lift the cams out, and pressurise right up to the inlet valve seats.
What sort of boost are you running to achieve that output? Looks fairly linear and spread over a wide range too.
I had exactly the same gasket fail at the SAU track day at Eastern Creek Southern Circuit last year.
The more people I speak to with modified R33's the more I am finding that this is a very common problem. When you consider that we a running a lot more boost than these gaskets are designed to cope with it should be expected, especially when you take into account the age of our engines. Once the gasket has been replaced and provided that the mating surfaces are flat they can sustain a reasonable amount of boost with a car in my local area running 22 lbs. with no problems.
Good luck with the Time Attack series.
Nowhere near enough people do a proper boost leak test.
I made this, fits onto the turbo intake, so I can connect a leak down tester and pressure the car while it's off and you can listen for leaks.
Edited by ActionDan
  • 2 months later...
Yep, haven't done anything to the motor.
We've replaced all the ball joints and some various bushes after NSW Time Attack. A bit of last minute stuffing around to get everything to fit and align.
Took the car out to Winton on Saturday. New pads and new brake fluid (the brakes were sh!T at Wakefield as well).
Track was extremely slippy in the morning session, then instantly overheated. Was just starting to some grip coming through in the afternoon session.
Work still to do
- alter the squat angle on the rear
- stiffer spring front and rear
- play more with the rear weight balance
  • Like 1
  • 1 month later...
Looking forward to seeing the car in action after following it for a while, I'll be sure to come by and try to fan girl on you etc.
Lol, come by for sure.
We fitted BC ER's to the car yesterday. The attkd rotors I bought have 6mm holes, while the ksport hats have 8mm holes. I had thought it was the other way around. So we have a little issue.
I'm hoping my tyres will be here on time...
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
