Enough meat in rotors to drill and retap?
There is, the 'tabs' are the same size as the ksport. The rotor is tough as nails though!
Was going to be bit of a risk getting them drilled.
So I hunted around and hopefully when I get home tonight the 8mm rotors are there waiting for me! :unsure:
All the best with WTAC mate.
One question, what do you by way of controlling oil surge? Do you have a sump baffle or restrictor etc?
Cheers
Amir
No baffling. Oil cooler plus long lines and 5L of oil.
No restrictor, long lines run from the cam covers to the catch can, then to atmosphere. The can ends up with 20-30ml after a day on the track.
Rev limit is set just over 8k, though the shift light is set at 7k. I only hold to 8k if it means less gear changes.
hey mate love reading about this car! hopefully get mine to yours soon!
What mirrors / where did you get them from? Price?
Also what spoiler and how wide is it?
cheers mate!
I'm not sure what the total width is, 1610mm maybe? It fits flush with the body, so isn't extremely wide.
I bought it second hand on the forums. I think it's a PSI parts knock of the BEE*R R#3 GTR wing.
  • Like 2
Is there any risk revving it to 8k on an internally stock engine?
You need to have the valve springs and retainers done etc to sustain the higher revs... Its not ideal but its not as if you are cruising down the freeway on 8k :P
my boost bleeds down to 15-16 by 8k. im sure if youre pushing 20psi the valves will start to float. im on the stock springs.
tao runs tomei springs in his 33.
im shifting around 7800 most of the time. it runs the limiter at wakefield and winton a couple of times a lap. it blows a little into the catch can, 20ml maybe.
I'd also like to know that, especially after reading the BC thread.
Amir
It was great having the ability to adjust the rebound.
Having only put them in for the event we are still learning how they react.
Don't have a bad thing to say about them.
Turn off the anti shake crap in YouTube that gives it the wobbles and makes it look like the Time Space continuum is bending around you.
lol, it's turned off. The arm on the camera mount is doing that (I think).
16s in, down the straight, that's the mount?
That's trippy.
It must be just at the right frequency to trip the camera out.
Any more work on the car Richo? What are the plans for 2015?
Play with the aero a bit, more power maybe. Not sure yet.
Still running a standard rear end, none of the arms are after-market. Might look at those.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
