Cage looks great mate,,,now the crappy jobs start.
Some poor bastard now has to sand every tube properly,,,prime them and then final coat them in your prefered colour. I subleted that shit job out to my favorite spray shop,,,he now hates me. I have some great looking tubes but some have dry coats which look bad. No way can you perfectly paint all the tubes to a price.
The real pain in the bum is some poor bastard (probably you) has to get under the car and wire brush all those floor cage welds and seal them or Mr rust will take over.
Cheers
Neil.
Funnily enough, yes it's a bastard of a job. We've used a wire brush drill bit and without that it would have been a nightmare.
I spent a day sanding the front half of the cage and painting it. The old man then finished off the rest.
So there are two coats of grey RustSeal over the whole lot now. RustSeal doesn't have any UV protection, so we either need to clear it, or what the old man wants to
do, get some KR4 made up with UV protection and do the cage and the gruby interior.
I think I prefer the RustSeal grey, it's much lighter than Nissan KR4. But I kinda like it.
Either way it's still not over yet, as under the car needs to be done.
Found this magic paint, RustSeal that you bush on. So no need to mask the whole car up etc etc.
Need more Power ? :rolleyes:
:yes:
You know what it's like, same old story of money. Going external gate, changing the manifold is a big time and money investment.
Unless you have a spare brae manifold I could borrow for a few months :closedeyes:
  • Like 1
:yes:
Get abe to modify your stock manifold to run external hate like he done to mine. Cost me around $500 including turbosmart wastegate.post-84279-14274102715192_thumb.jpg
Probably, doesn't make that much power.
The last test it made 292rwkws on 18psi after cooler but showning holding perfect flat on 25psi precooler, That should make towards 350rwkws on pump once a proper cooler is installed.
Yep, I'm following that development at the moment. From memory I'm making 18psi @ ~3400rpm on the current turbo, so extremely responsive.
Maybe we should take the R34 out to Sandown on the 4th of April and do some track testing ;)
I'm running a Greddy LS cooler, seems ok...
Regarding ride-height..
Your car appears to ride significantly lower than the typical 350/340mm axle->arch measurement recommended by numerous people on this forum. At a guess I'd say it's closer to 330mm front and rear?
Based on your experience, how have these geometry changes (lower roll centre) affected handling?
I found at those heights I couldn't get the camber I wanted on the front. That too me is more important than bump and roll.
It sits from 325-335 depending on the track and conditions on the day. Starting point is 5mm front to rear difference though.
It has some bump tie rods in the front, though I couldn't feel the difference.
  • Like 2
Cage is all painted, might need a bit of a tidy up before WTAC so it looks pretty.
Dash is back in, with the cluster. Cleaned up a bit of ugly stereo, turbo timer, alarm system wiring while I was at it. Though the boost controller and shift light still need to be wired back in.
Screen goes back in it today.
  • Like 3
So after the fun day at Sandown there was a list of things to check off, to get the car back performing it's best.
1. check swaybar location
2. fix floor surface under the pedals
3. install roll cage padding
4. diff and gearbox breathers
5. front left steering movement
6. front splitter mounting points
7. fit new harness
So in went the new harness to make the HANS more comfortable.
Added another items to the list, that is give the inside a good clean with de-greaser
The movement in the front left was a loose bolt, with that nipped up movement was gone.
Also backed the swaybar off a hole. See if the front of the car is any different next time.
Added tanks for the diff and gearbox
We've been talking about bonnets for a while and trying to find a cost effective unit off the shelf that is aero and heat effective.
Failing to find one, we dropped two new wheels on the angle grinder and went to it.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
