So NSW Time Attack comes around. After the madness of getting the car ready and actually getting to the event.
285/35's are very tall, so we had to massage the tubs a little. With the castor and under load there was some rubbing.
  • Like 1
I've only been to Wakefield once and that was for the SAU Nats last year.
1.07 I think the time was.
So this time around I've got less weight, little more power and wider tyres.
1.04.9 on the coldest two days on earth, I though PI was cold in Winter, this place has nothing on PI.
It took a silly amount of time to get the tyres up to temp, we used so much fuel that after the second run on day two we had run out.
6x 20L cans and 60L in the tank, gone.
Most others were using Martini, which was no good and guys running Surogen were out and re-tuning for Martini.
  • Like 1
It's been decided that the splitter is not low enough to fully utilise the air and that the lower lip design wasn't the best aero wise.
So we knocked a template out of wood. We will be attaching the front in in a way that makes it easy to get on and off. Also need to look into the fasening system from the splitter, as that needs to be structural to the chassis not the front bar.
We also enlarged the intercooler opening, which isn't better for aero, but is for cooling.
  • Like 1
The wing sits low on the standard GTR stands, so up it goes 30mm. These are made from 3mm alloy, one on each side of the wing stay.
Also notice the go fast tape around the boot from NSW Time Attack.
Also trying out some F1 inspired wing end plates. The old man cut these out of 2mm alloy, with the angle grinder.
  • Like 1
Some toys to fix the diff. A little gearbox maintenance with a new seat for the shifter and a new selector bush.
Also people go on and on about roll center and bump steer. While I understand the mechanical theory, in practice on the track...mmm not sure.
My front tie rods are not even near horizontal with the car is jacked up and suspension unloaded. They are still a good 10mm higher at the knuckle.
So I'm smashing out good times, with the front arms pointing skyward. I think the car handles extremely well. So I'm further interested to see if these KTS rod ends make any measurable difference to the way the car handles.
We changed the studs over to 70mm NISMO's a while back and now I've got some real wheel nuts. 2 piece project mu's.
  • Like 1
Tyres, tyres. I know on the current set of wheels I can just squeeze a set of 285's on there. I'm sure 285/30 will fit no worries.
But....is there going to be a difference, even 0.1 seconds difference in going to a 295...
Now a 295 is going to bulgde the hell off a 10" wheel, so i'd need a 10.5. To do that the offset needs to be way out there.
10.5 + 15, GTR offset....on GTST guards...I think not.
So the question is, should I butcher the guards (which we are allowed to do this year) to fit the tyres.
This is a shot of the current set with a 30mm spacer (around the same offset as the 10.5). The wheel is loaded via a jack to running height.
  • Like 1
I'm interested to see how you go with the tyre monitor, what is it? How much etc?
Brother bought it as a birthday present. Not sure.
It's going to save waiting time in the pits between warm up laps and hot laps.
As generally, it go out and blast a 80% lap, come back into the pits. Make sure the pressure are good, then go out and hit up a fast lap.
The car sits around heat soaking while the pressures are checked.
So as long as we calibrate the pressure readings from the senors with a good external gauge, it should be useful.
Do you struggle for rear grip at the moment or is purely chasing more corner speed? In which case I'd be thinking the fronts would be the main concern?
Ah OK, well let us know how you go with it, and what tyre pressures you run etc.
I'd also be keen to hear what alignment settings you're using, though you can PM that if you're happy to share but don't want to over-share as some people don't.
Edited by ActionDan
front castor -7 deg
front camber -3 deg
front tow +0.8mm (ea)
rear camber -1.7 deg
rear tow -0.5 (ea)
The camber settings change a little as we lift the front and rear regularly to find balance for the conditions. This also changes the tow slightly, though not much with the R33 arms.
I haven't got any adjustable arms on the rear, so the standard camber bolts are pushed all the way to max positive.
Wheel alignment settings go together with the spring choice, sway-bar setup, rake etc.
  • Like 1
It makes me happy to see a car which gets driven properly - I love the re-shells in the first few pages.
Good on you for driving your car and not sitting it in the garage worrying it will get hurt - like seems to happen a lot these days.
Great driving too, maybe i'll meet you at the track one day.
You should be commended for the time of 104.9 on a cold day as the lap record for the V8 Utes is a 108.00
Whitline make a replacement adjustable front sway bar link KLC108 that is stronger than the standard unit. Here is a link to their site. http://www.whiteline.com.au/product_detail4.php?part_number=KLC108
You will butcher your rear quarters trying to get the 295's to fit. You could roll and flare out your quarters a good bit more than what they are ATM, but chasing THAT much the quarter will sink further up and scrubbing out under full load will haunt you I reckon. I've pushed mine to the limit without major work, ie heating, pin pulling a totally re shaping. No way I'd get them under my quarters.
Super awesome job on the 1.04 mate. it was good to meetyou and see this car in the metal too :)
How much power is the car making now? Im lucky to hit 185km at the kink. but it may also be that you're carrying a bit more speed through the last corner and can get on it eairlier.
Are you going to make a fibreglass spiltter/airdam?
Have to get the diff back together and the front splitter sorted this weekend.
I want to get out testing AD08R as soon as possible. Yoki have an event on the 3rd of August, so that is the aim.
http://www.yokohama.com.au/en/ADVAN-Motorsport/ADVAN-Neova-Cup/ADVAN-Track-Days.aspx
My brother has also been designing a rear diffuser.
It's actually built now, but no pics of the actually until it's all done :closedeyes:
  • Like 1
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
