On my evo the oem side mount oil cooler (even though it gets air from the front of the car) doesn't evacuate into the wheel well efficiently and temps skyrocket after a few laps on a hot day.
I've rigged up a water spray which I need to better test, but should help.
Just thinking you might need something similar or use a 12v fan if airflow isn't available.
Ps. my r34 loves the oil cooler in front of the radiator.
  • Like 1
Really, I found the oil temps lower with it in that location.
  • Like 1
Problem with it in front of your radiator is it can cause coolant temp problems on the track. To solve air flow issues with it side mounted you can Swiss cheese the inner guard if your still running it
Not sure if you saw, there is a major air flow issue. No air getting to it.
I'm not running guide liners at the moment, but will be when I've got time to make some.
I did think about re-locating in-between the intercooler and the radiator. But I want to keep water temps as low as possible. I've run it there previously and both water and oil temps were higher under sustained load.
Work on the car last night.
As is always the case, things take a while. It was 7PM before we left finally.
Then to wake up the next morning to a missing left wing end plate (fasteners came loose, lost it on the hwy somewhere) and ice.
1.35 on a drying track pedaling around at 80% bedding things in. I thought for sure I was on A050's, the AD08R straight off the bat surprised me. Seems like they are going to live up to their hype.
You can see the NACA duct here, doh!
  • Like 1
With the splitter on now, 1.34 again on a drying track (the damn rain kept coming through).
Not sure what the temp was, cold! mother F$%ing cold.
Dropped the pressures back to 30-31 hot
1.33.38 on AD08R's, street tyres. Love em, such a progressive and predictable tyre. Did a lot of laps in both wet and dry during the day, 40'ish. Tyres still look very new.
After working on the car all week after work and 16 hours on Friday, I was pretty tired and my brain started going off in the last session I did. 1.32.8 was the optimal time on the lap timer for the day and that was easily achievable. I made mistakes on all my hot laps in the last session. With more practice without ABS (this is only my 3rd time) and a more speed conducive day 1.31's are a go'er.
  • Like 1
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
