see the pic!
History
rb25de neo in a r32 shell
all supporting mods - fuel, ignition is not an issue (wasted spark setup), external gate is off the turbo exh housing at 35mm. air flow meter is a functioning z32 afm. tune is thru a nistune (or chipped std ecu).walbro 255,
turbo is 'unkonwn' but has been reported to me as a t04 variant. but from the graphs, it spools fairly late and should make more power than it is. the worrying part is the odd dip!! does anyone have an explanation or a theory from prev experience?
exhaust is 3" from the catback at least
attached dyno sheet is from the above config
my tuner thinks it could be a cam timing problem or an upset turbo with missing blades etc.
any help or suggestions much appreciated.
  • Like 1
https://www.sau.com.au/forums/topic/428551-help-me-with-my-dyno-problem-please/
Does the car drive like that dip shows??
What has the tuner said?
EDIT. I highly doubt its damaged turbine fins. Cam timing, nope.
Just by looking at the graph, it looks like heaps of ignition timing is being pulled.
thanks for the responses people. The tuner recommended that I check the cam timing. The crank angle sensor - if faulty -should have given off some signals (e.g. vibrations etc) if it was the cause but I will be getting a replcacement to troubleshoot that as well. The tuner tried to smooth out the curve with everything he had at his disposal, added a ton of timing at the dip to try offset potential ignition issues etc. no luck. so we returned everything back to 'standard' so I could troubleshoot the issue without worrying about how it would affect the tune.
Turbo issues is last on my list but with such a good spool and also a carry on on a decent boost curve after the crazy dip, then i doubt the tutbo is the issue here, i am betting on some sort of cam or valve priblem when it hits a resonant frequency.
any another ideas are most welcome, the turbo should be making another 50kw and it is unfortunate that i am missing that power
as far as I know, boost is holding steady at 12psi through the rev range - measured on a prev dyno run which was done on a hub dyno. this time round we didnt have all the sensors hooked up through the wheel dyno so I can't be sure, but I had the dyno operator working the 4th gear pulls and keeping an eye on the electronic boost gauge and didnt notice any sudden drops.
one thing to note is that the z32 afm voltage ramps up to ~3.4v and then holds which indicates some sort of flow problem somewhere - it maxed at 3v last tune, and I found a baffle in my exhaust had caused a restriction. so I replaced the entire exhaust and now making 40kw more, but still something is wrong ...
sounds weird. I would be concerned that the tuner tried adding heaps of timing to counteract the dip, rather than find the root cause.
In your first post you mentioned functioning z32. What do you mean by that? Had it been tuned in another car and behaved normally? Any fault codes present on ecu?
Edited by superben
the tuner added timing to try get rid of the dip but it had no effect. It was done as a diagnostic measure to try eliminate possible reasons for the dip. if even a really advanced spark doesnt make a change, then the problem must be mechanical right?
the z32 afm has not been tested in another car, but it has not shown any abnormal behavior. it has fine resolution up to 160kw initially, and then again up to 200kw on the second tune (around 3v on the first power level, and 3.4v on the second). I would expect if it was the afm, we would be seeing some weird outputs and perhaps even a flow ceiling, but the second tune with an increase in power and hence flow resolution sort of rules that out.. but if that power/torque curve could be a result of a faulty meter, then I can definitely add that to the list of things to diagnose.
no fault codes were found, and my tuner removed all safeguards temporarily to make sure the computer wasnt trying to safemode or anything, for example, fault knock sensors can cause the ecu to pull lots of timing to protect the engine when there is nothing wrong, so we pulled that to be sure it wasnt.
essentially my tuner has eliminated all possible electronic causes out, hes increased the output of the ignition system, there is no missfire and there is plenty of fuel.
current tune now has no ignition dumping to try quick fix the dip, holds a safe AFR throughout the range, so its up to me to try find the cause. if I can fix it, the ecu should be able to relatively safely extrapolate fuel and timing to keep it safe, but i will definitely put it back on the dyno
  • 3 months later...
cleaned out the intake manifold - removed the silly butterfly valve in the neo intake, regapped the plugs and ran a compression test
cyl1-6
200, 120, 170, 160, 170, 190
would the low values on #2 cyl cause these issues?
worth swapping a new short block with 190psi across the board?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
