Im just looking for some advice on upgrading auto trans. I'm driving a stock R33 SII (apart from the nifty nismo front ) I really dont know much about available options for automatics. What I would really like to fit would be a automatic trans with a sequential shift like the ones out on the new fords. I could always convert the car to manual but I feel that would be too much of a job.
https://www.sau.com.au/forums/topic/42856-improving-my-gts25t-auto/
yeah, don't belive anyone that says that auto's are shit, because they aren't.
DO what RNS11Z says, and then bomb your motor, and you'll have a nice little car that will change quick, and be good in straight line drags
Actually i believe its the other way round kamikazee. Your going to need a shift kit for the Auto. If you want 200+rwkw get it rebuilt with stronger internals, a new stall converter and bigger trans cooler
Do u know any where in brissy that does auto gtst gearbox mods?
actually the R34 tiptronic is the kind of thing im looking for. I dont want to buy a 34 because... err.. i just bought this 33 but yeah is it possible to get something like the R34 trans installed in a R33?? Otherwise im not complaining about autos at all. If I wanted a manual right up i would have bought one. (I do long drives as well as driving through the CBD and clutches frustrate me in traffic) It would be nice to have just a little more control over the gears when needed. I'm looking into shifts kits, is JATCO the thing to look for??
i cant find contact information for JATCO in japan but they have on their website a 5-SPEED Auto Transmission for Skylines. Unfortunately thats about all the info they give out. theres no links to a technical specs and not even an email address to ask them. who here knows about these transmissions and can they go in a R33 GTS?
your local auto workshop should be able to do some mods to the auto box aka stage 2 shift kit, which i believe helps in quicker changing of the auto box. as others have said, upgrade ecu, cooler, boost controller, air filter and you'll find the auto should be still fine
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
