I have or had a series 1 rb25det in my 240sx. I have s-tec manifold, borg warner s366 turbo with all the basic supporting mods like intake manifold, AEM EMS and exhaust. I messed the motor up and now I'm searching for a replacement.
The NEO rb25's are getting pretty cheap over here in the states so I am considering converting over. I read on SAU about the neo motor being an all around better foundation than the basic rb25det. Having the solid lifters, rb26 rods and vct makes me want to upgrade this go around. Everything I have will swap right over including the wiring harness. I'm using GM coil packs and the sensors that are required for the AEM like the IAT and MAP.
If you are using the AEM EMS then it is required to swap out the CAS oem disk with the new one that AEM sells. This disk works only with the series 1 CAS. I've been doing tons of research and I can't find anyone that has used the AEM ems with a rb25det series 2 or neo with the black plastic CAS.
So I was thinking if need be I could install the neo RB25det engine and just convert the neo cams with the series 1 cams in order to use the series 1 cas.
-Is this possible??
-Will the AEM EMS work with the NEO CAS?
No cant swap cams. Hydraulic cams in solid lifter valve train = no.
If AEM says the disc will not work with a NEO then it probably wont work.
Change to a crank trigger system or get a CAS disc custom laser cut.
Besides mega squirt what other stand alones are out there that uses the crank trigger system?
If I don't convert my standalone then I guess I have to stay with the series 1 huh??
Err most aftermarket ECUs will happily read a hall effect or VR sensor from a crank trigger.
If the AEM cant then its not a very good ECU.
Link, adaptronic, motec, haltech, megasquirt, autronic, vipec etc etc can read a simple hall effect input. Although I believe the megasquirt prefers a VR sensor.
  • Like 1
Is it possible to use an R32/33 RB26 exhaust cam in a Neo head and and retime it ? Solid cam so to speak with the right CAS drive ?
It may pay to research the base circle diameters of RB26 and RB25 Neo exhaust cams .
Just a thought cheers Adrian .
Edited by discopotato03
Neo cams have higher lift so good to keep. For most cars swapping the CAS type just involves reversing the wiring so I would have thought it possible to make it work even with your aftermarket ecu.
I always knew that the lift and duration are different on all cams but what matters is the gap between the cams and the lifters right?? I've heard about people installing rb26 cams into an rb20 and swapping the s1 cams with the s2 cams.
I know I could do that. I would hope that what ever flaw that the s1 CAS has might be corrected in the NEO cas....
Wouldn't it just be easier to do what you have to do to fit the right CAS onto the cam? You could manufacture an adaptor, or you could weld the end of the cam and remachine it with the right drive. The options are bound to be more plentiful.
There is a local machine shop that has been around for years. I'm sure it would take some sort of computer program and nifty machinery to get this done. Might not be worth it doe.....
A good machinist could do pretty much anything with a lathe, a mill and a pair of verniers.
I wasn't suggesting it as the big solution, just offering up some alternatives. Interfacing one rotating assembly with another rotating assembly is something that car modifiers have been doing since forever. Used to get done with various distributors in order to get electronic ignition onto older engines (as an example).
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
