I am thinking of wrecking my A31 ceffy. It has a turbo rb20 and its auto. The car runs ok but has some leaks here and there and other minor faults. The body is straight and it is registered. I have been trying to sell it for a while but no luck and I need the cash. I'm hoping to get $3500-$5000 for the parts.
The car has some mods including after market rims, exhaust, coil overs and K&N pod and other bits.
If there is a satisfactory response then I will go ahead and wreck it. I can be contacted by pm or 0420 593 194
The car is in WA but I can ship at the buyer's expense. Will post pictures shortly
Let us know
https://www.sau.com.au/forums/topic/428611-cefiro-a31-wreck/
Post the actual car up with some pics and you might get some more interest.
I saw a turbo factory manual on gumtree not long ago for 3.5k that was very mint so might give you a gauge on price. Unfortunately we really make money back on parts and being in Perth will reduce the price further.
I'd be interested in some interior bits and pieces if you end up wrecking it.
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
