Spent last hour making a thread with pics.
Site wouldn't post it.
So f^$% doing it again.
ALL PARTS COME OFF A GTR THAT WAS RUNNING FINE BAR A BUSTED HEAD GASKET.
Nearly died, need money to pay off medical expenses (seriously.)
PM ME WITH WHAT YOU WANT, AND I WILL GIVE YOU A PIC.
ALL PARTS FOR SALE.
I WILL PROVIDE PICS WHEN YOU PM ME BECAUSE I AM NOT SPENDING THE NEXT HOUR PUTTING PICS ONLY TO HAVE THE PAGE MAKE ME LOGIN TO HOME AGAIN AND DELETE EVERYTHING.
Not posting anything as I work five days a week, so you'll have to come to north sydney to come get them. Sorry.
MMMMMKAY?
Keeping brakes, seats, key and ign' barrel.
BODY PARTS:
Hood (with liner) - $280
Front guards - $100
Front bar (minor scratch on front left corner) - $200
Boot lid + Wing + badges - $180 (Wing paint has the clear baked off, other wise in good nic.)
Grille - NO BROKEN TABS/CLIPS! - $100
Front lower guard bodykit pieces - $25 each.
Guard liners - $50 a corner.
Door shells (drivers side has a scratch down low, no dents though) - $150 each IF YOU WANT COMPLETE DOORS WITH GLASS TRIMS ETC, 300 each, bolt 'em straight on your car.
Wing mirrors - Pass side has baked clear - $50D, $35P
Door rubbers - $200 for the lot.
Door kick panels - $10 each with push clips.
Hood latch, support, front brace and cable - $150
Headlights - $100 each (including bulbs, no broken tabs)
Indicators, LH has broken top tab, $25 bux for it, $40 for RH indicator (with bulbs)
ENGINE/MECHANICAL:
C.A.S: $200
C.A.S Alloy bracket - $30
Cam gears aftermarket "Spool" - $40 each.
Cams - $80
Coil packs on rails - $220 for them plus the rails.
Coil pack loom - $50
GTR Injectors on rail - $150
Injector loom - $60
Radiator (flushed and clean) - $60
Aircon crap all of it, pump, etc - $100 for the lot (engine bay stuff, not inside stuff.)
Fuse and relay box - $100.
Airbox with filter - $100.
Washer bottle with motors (And fluid!) - $80
Coolant bottle - $40
Alternator - $80
P.S pump - $120
Brake booster - $150
P.S reservoir - $100
Cam covers - $50 each
Coilpack cover (No badge, wrinkle paint) - $80
Front cam cover - $60
Intercooler - $150
Intercooler piping - $120 for the lot, front cross pipe, main pipes all the way from turbo to intake.
Intake plastics (lower air box thingo, rubber pipes, and plastic piping) - $10 a piece.
The big thing on the pass side of engine bay with all the brake lines running to it, HICAS, etc. thingamijiggo - $200 sounds fair?
Turbo manifolds - $80.
Turbo manifold heatshields - $30 each
Stock turbo's - $100 each.
Turbo piping - top hard pipe, no badge $35, top rubber pipe $25, metal pipes off turbo's - $15 each.
Exhaust - $300 from the turbo's back.
Intake plenum (when I finally get the F@#$ing thing off) - $200
ITB's - $200 (unless I magically get an L28 Motor and a Zed then they are going too.. lol)
Head with valves (no cams) again when I finally get it off... - $450, valve seats in good nick, will provide the Tomei restrictor with it if you want.
Sump - $250.
GASKET KIT, complete factory one - $250.
Fuel pump & Tank - $260
Clutch cyl, booster and lines - $100
Block - $1200.
Pistons - $150 for the lot.
Rods - $150 for them too.
Crank - $240
Fly wheel - $250
All the oil lines and oil block, returns etc - $300
4x Airflow meters - $80 a pop.
DRIVELINE:
Gearbox - $450.
Clutch (good, good feel to it) - $200
Tail shaft - $180
Rear Diff - $350
Front diff - $280
Rear cradle with control arms, etc - $200
CV's, front and rear - $40 each.
Front hubs with bearings, no discs or calipers - $120 each.
Rear hubs same dealio - $100 each.
Front suspension arms - $200 for the whole shebang each side.
Factory suspension, good nic - $250 the lot.
HICAS steering rack - $120
Front steering rack with rack ends and tie rod ends - $180.
Sway bars - $80 each (F&R)
INTERIOR:
Rear seat - $180
Floor mats, F&R - $140 for the lot.
All interior plastic trims (bar center fascia as it's busted), so pillars, rear pillars, rear side seat trims, B pillar trims, kick panels etc - $500
Carpet - $200
Gauge cluster - $120 genuine 147 k's.
Center triple cluster - $50
AC controls - $50
Rear aus compliance window brake light - $100.
De-ioniser - $140
Rear parcel shelf - $150 (will throw in speakers, I think they work.. lol)
Roof lining - $140 (needs a clean, otherwise has no burns or tears I can see.)
Top center interior light fixture (complete unit) - $60.
Rearview mirror - $40 (good condition)
Sun visors - $25 each, pass has mirror.
Dash - good condition as far as I can tell, NO VENTS - $300.
Interior fuse box - $100.
Interior AC box - COMPLETE - $250. (looking for the heater valve control motor thingo for a guy who has PM'd me, hope it isn't inside the box. lol)
Glove box with string stopper - $60
Factory ECU - $150
Seat rails - $Not sure as I may be keeping them for the RX7 as I am keeping the seats, as the RX7 seats aren't comfy for me as I now have to use it as a daily driver.
Seat belts, GENUINE NISSAN good nic - $160 for the lot.
All boot trim - $200.
Space saver tyre original - $130.
EXTRAS:
Shell, registerable - $3000, no rust (includes glass)
4x 225/40/18 Pirelli's - $200 at 50%ish tread
ANYTHING ELSE JUST ASK. :-)
Edited by RBMunkie
https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/
PASSENGER DOOR locking mechanism has been sold to
gtr0321994.
Shifter boot and heater control valve sold to: (as far as I am concerned.. lol)
luke GTR
Edited by RBMunkie
Dash:
No bubbles I can see.
The controls around the gauge cluster?
$40.
R32FREAK - the front bar and reo is sold.
But I still have the guards, hood and latch and front support and brackets.
Oh sweet, thanks for pic; ill have a think abt it. But also do you have the pipe that connects the twin turbo pipe to the intercooler piping (in pic below) and would you sell it separately as i need one badly. Thx.
IMG 4473
Chasing the following in good condition
>> 1. Interior door handles
>> 2. Rubber seals/linings around door windows
>> 3. inside triangular pieces opposite the side mirrors
cheers
adam
  • Like 1
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
