Hey SAU.
There is almost nothing in terms of topics about this type of ECU.
From what i know, they were re-mapped ECU's from the Omari factory. But what I don't know is what has been changed to the ECU map. I'd assume slight advance in timing & boost?????
Would it be similar to the "Mines" ECU, and would it be any good for an R34 GTR in Aussie climate?
I have found a unit from a Vspec II which could be of interest to me (I have a 99 Vpec)
Any thoughts??
https://www.sau.com.au/forums/topic/428640-nismo-sports-resetting-ecu-bnr34/
Hey SAU.
It would just be a re-programmable ECU tuned by Nismo for their "Nismo Sports Resetting" GTR's.
Suited to Japan climate / fuel RON etc.
Any thoughts??
Just get a Nistune done to your OEM ECU.
Thanks for the replies. I was always planning on a Power FC as they can be had for sub $900. Was just curious about the "nismo" package. ECU itself would be pretty rare, if it were "tunable" simliar to a Nistune ROM that would be pretty cool to have on your shopping list.
Cheers guys
Of course you can Nistune the R34 GTR ECU. You can do any of the RB26 ECUs. You can do the R34 GTT ECU. The only ones you can't do are the R33 GTST ones (and a few that we don't care about).
Type 2 boards cover the following earlier consult vehicles:
• M30 Infiniti (VG30E)
• ECR32 Skyline (RB25DE)
• ECR33 Skyline (RB25DET)*1
• HCR32 Skyline (RB20DET)
• BNR32 Skyline (RB26DETT)*2*3
• Q45 Infiniti (VH45DE)*4
• U12 Bluebird (KA24E)
• Y60 Patrol (TB42E)
• Z32 Fairlady 300ZX (VG30DETT)
Nistune uses a daughter board for real-time tuning using a modified version of Nissan Consult. It provides faster transfer rates, realtime modification of maps, constants and tables using the Nistune software.
Provided with CPU connector, 28 pin socket and instructions
Note: You will require a consult cable to connect the laptop to your vehicle. Tax, shipping and transaction fees may apply
*1 ECR33 RB25DET Skyline can use HCR32DET ECU (no VCT) or Z32 VG30DETT ECU (internal modifications required)
*2 BNCR33 Skyline requires BNR32 RB26DETT ECU and O2 sensors
*3 BNR34 Skyline requires BNR32 RB26DETT ECU, O2 sensors and CAS wiring modifications
*4 Q45 VH45DE (1990-1992) using removed high gear maps
Taken from the Nistune website. It can be done but its not simply a "plug and play" I guess..
Edited by nomnomv8
Oh, valid point. I forgot that even the R33 GTRs were to use the R32 ECU.
It's not hard though. Install different O2 sensors and swap a couple of CAS wires. Adds to the expense of having to buy the sensors though, and I think you lose the MFD on the dashboard too.
Perhaps it's not a great option. Mind you, any other aftermarket ECU has the same or bigger costs and problems.
Have you priced nistune? Don't use a power fc
Having used both they are both good options.
Nistune is a bit more costly than it appears at face value if you also pay for a user licence and interface cable. PowerFC gives you a commander in the glove box for basic sensor checks and for tune tweaks.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
