Hey. Help me pleace, has serious problem. Have asked and searched around without result, is a bit desperat. So I hope some one can help me.
Have an s13 with RB25DET Generation 2, with:
Eagle rods
CP piston
Tomei poncams
80mm throttle body
aftermarket intake
ported Garret GT3540r .82 ar
Split Fire Ignition coils
Link G3 ECU
1.2 mm head gasket
Denso 850cc injectors
Aeromotive A1000 fuel pump
Apexi avcr
52mm wastegate
adjustable cam gears.
Have run it on the dynapack, according to the afr it leen out between 4700-5000, I cant gett higher rpm, but if I keep the pedal to the floor in a few seconds it goes over 5000rpm and hit the barrier at 7500 RPMs with no problem. Nothing is registrated in the link g3, it is the same problem when standing still so when I drive the car.
Any settings that are wrong?
Some one have a mapp I could try or compare with?
https://www.sau.com.au/forums/topic/428661-problem-with-rb25det-tuning/
I just looked at the map you sent me, clearly there's less fuel between 4500 rpm and 5000rpm which explains your flat spot.
Don't use the AFR targets and assume it will work on load, you need to adjust the 'Fuel Table 1' tab, your timings look safe enough at 1bar at 17 degrees on song till redline.
see at 100kpa at 4500 it's set at 48.2, then at 5000 it's at 45.3, etc,
Thanks. I have to take a look at that.
are the injectors side feed? or did you convert to a top feed with the aftermarket plenum ?
what injectors are they exactly? got a part number?
Denso 850. Side feed. High-impedance. Dont have the part number, can take a look att the injectors, meybe i find the part number on the injector.
has it got a vct fuel or ign compensation table sounds like something to do with vct?
he emailed me his map, it just looks terrible... he's only configured the AFR targets table and left the fuel table as is, there's a total lack of fuel where he's car is leaning out. You can just look at the map and tell it's going to lean out without even needing to put the car on the dyno
