OK, so I have a few shipping containers laying around at work and I'm running out of space at home to store cars, so thought I'd investigate slinging a car into a container.
First, and most fundamental, hurlde is getting the car in there. The floor of the container is about 160mm above the ground and I need a pair of ramps to get the car in. Ideally they will be removable as I don't want there to be any outward signs of there being something of value in there, so therefore light enough to man handle. They also need to be a suitable length to ensure the car doesn't ground its self on the way in. I'm thinking 1.5 - 2.0m, but that's a guess.
Easiest thing would be if someone has done this before and knows what works well.
Any suggestions. Yes, I've searched google. I'll also ring the local car storage business to see how they handle things as they use containers too.
Thanks.
https://www.sau.com.au/forums/topic/428664-shipping-container-ramps/
Something like this would be perfect:
http://www.ebay.com.au/itm/Car-Ramps-/330955394821?pt=AU_Car_Parts_Accessories&hash=item4d0e7a8f05&_uhb=1
Exxy, but if you're going to be using them a lot it's probably reasonable.
Edit: Might have to modify them to sit at 160mm high.
Edited by colourclassic
Just use some bits of timber. Use bricks/rocks under it so the timber is supported.
Remember to put a moisture absorbent in the car once stored.
What does a 'moisture absorbant' look like and where to get it from? Like a large desicant pouch?
Yeah, you can get container sized pouches, or just a product from bunnings called drySorb I think. Little flakes you put in a holder.
You just don't want to come back a month later to a mould factory!
As above...
...or more cheaply...
1) Takata Low Ramps
...often used by owners of Japanese cars with low lips (before jacking) and this strong plastic can support the front of most cars
2) Sacks of rice
...as rice is used in salt shakers as a dessicant
As above...
1) Takata Low Ramps
2) Sacks of rice
Thanks Terry. Takata too small in height and length and will consider rice option! It's looking like I'll have to custom fabricate something out of SHS and chequerplate. Heavy!
Take a trip to Bunnings, etc and head to the timber section. Get some garden sleepers. You can easily make some ramps out of them that will hold the weight of a car, especially if you brace them in a few spots where they are off the ground.
That's what I use - cost about 10 bucks each - I got them to cut them in half. Solved my driveway issues:
do what we did at work when we had to hire two sea containers that needed forklift access
speak to the company you got the container from and they will point you in the right direction for some ramps. . we had a forklift + a 1 ton load on the ramps with no clearence / load issues and they butt up to the container floor and you could still close/lock the container without moving the ramps
Or buy some ebay china special ally ramps. Come in various sizes.
they have a lip that will sit on the edge of the container and aren't heavy to move around.
http://www.ebay.com.au/itm/2-x-Aluminium-Heavy-Loading-Ramp-323cm-1805kg-/390408180987?pt=AU_Motorcycle_Parts_Accessories&hash=item5ae62414fb&_uhb=1
Have done this before and have two methods to share.
1. If you dont intend on getting the car out often, just get some clay dirt or something to that effect and build you're own ramp. Good thing about this way is you can customize the angle and length / height of your ramp. Worked for me and a friend getting a lowered car into a storage container that probably would have been about 15cm or so off the ground. As soon as your done shovel the dirt and clay back up and away you go. Doesnt take too if you dont mind getting into the shovel work.
Otherwise go to supercheap auto and buy a pair of loading ramps. Theyr about 16cm high BUT they wont suit a lowered car. To get around this get a few planks of wood for each side to help ease the transition onto the ramps.
Don't like the dirt idea but will check out Supercheap and how they could be modified to suit
Looks rally good. Not too expensive, wide enough, strong enough, light, but I think the feet are designed for a much larger angle. Container deck is only 160mm off the ground.
I'll do this but I don't want any outward sign there is a car in there and therefore want to ramps to be removable by hand. Also the fork ramps may not have the length needed to get the guts of the car over the hump
Yeah, we have a fair bit of timber at work so 1 option is to laminate some progressively shorter lengths of timber (say 150 x 25mm pine) to make a ramp. I'll run a few designs I've come up with past the carpenters and see how they think it will hold up. Marine ply would be too heavey to do this with but would be ideal in terms of the height progression and being able to make the ramps 300mm wide.....
http://www.stanfred.com.au/prodpics/resize_1366938992.jpg
Found these. Not sure if long enough and also they're 25mm too tall and I'd have to cut off the ramp handle as I'd be driving over it in this application......
Then there are these but they are too light wieght. I guess I could work out how to support them
http://media.supercheapauto.com.au/sca/images/285535.jpg
Seriously - for the sake of getting a car from point a to point b I think you're over complicating things. Grab some planks of wood - support them on bricks where they transition to the container floor and drive that fker in. Throw planks in container - don't think about it until you have to get your car out.
I have to go through this every time I want to get my car in and out of my driveway - sure its a pain - but it takes literally 5 mins.
Harhar I think you're right! That said it'll be an inconvenience enough getting the car in and out and I CBF dealing with bricks'n'planks'shit, especialy in the dark and the wet. You're a more patient man that I. Plus I like things to be done right. I'm over 40 so I'm allowed to be a little fussy.
I'll postup the final solution, so thanks to all for your contributions.
Only last thought I had was the heat in these suckers in the summer. I'm guessing it'll be nice and toasty in there (60 - 70 degrees?). Any issues relating to the health of the car and the heat?
I would just make sure you leave the windows cracked so humidity doesn't build up inside leading to rot. (Side note : read the article on what has happened to the Sultan of Bruneiis car collection in storage). I was going to suggest some of those extraction fans that mount on your window - but they are solar powered - wont exactly work inside a container.
Perhaps one of those damp rid containers in there - It will soak up any moisture.
And a car cover. Although I imagine they're pretty water tight, they won't be air tight and dust and crap will blow around in there eventually.
Disconnect battery and take it with you. Firstly it's a good anti theft measure. Secondly you can put it on a trickle charger at home so it's ready to go when you next are.
And you might also want to consider securing the container itself. They might not be able to get at your car easy - but it's a piece of piss to load a container onto a truck and transport it somewhere else - after all, that's what they're for ;-)
Humidity we've covered and I think I'd rather leave the cover off. Something in me tells me it's better to let the car breathe a little. I'm locating the container near a power source and will leave the battery on trickle charge in the car for fast get aways (hopefully mine!). I actually never thought about someone lifting the whole container and taking it off so you make a very good point.....Dunno how you stop a side loader and an angle grinder.....Have to get a Doberman for the yard!
I should look at a dehumidifer! About $500 from Bunnings by the looks of things. May as well carpet the container and get it climate controlled...and move into it.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
