  • Replies 48
Do still have these parts?
2door power window motor
ignition barrel plastic ring
indicator stalk or turn/bright switch
power window switch Left
quarter glass, with intact rubber molding
Don't suppose you'd happen to have a standard battery brace? the one that bolts to the rad support?
Hit me up on 0419170619 if you do. happy to pay postage.
  • 3 weeks later...
R32 parts for sale plus a few other bits
R33 rotors. Calipers.hand brake cables and drum assembly with knuckle $130-
Under dash panel driver side with fuse box cover $20
Stock r32 side mount intercooler $50
A pillar trims $30 each or $50 for a pair
GTST air con condenser $70
2 x r32 hand brake and cable $70 each
GTR front strut brace $100
1 x pairs of r32 5 stud front hubs and up rights $100 a pair
4x lower quarter trims $30 each
Rubber gear box surround with metal ring $20
2xglove boxes
Under dash trim panel $15
R32 glove box $30
3 x speedo clusters 2 x grey, 1 x blue dials $80 each
2 x climate control unit $70 each
Centre console dash panel radio surround $40
Upper rear trim driver side all clips still there cracked in corner otherwise good con $40
Rear bar $50
Rear reo $70
Tail lights no covers $40 each
Steering Colum surround $50
Rear parcel shelf $40
Centre console ash tray $10
Window black box driver $50
Front bonnet latch and support $50
2xwiper motors $40 each
RB20 speedo cable $70
Nissan din pocket $20
Washer bottles rad overflow and washer $40 each
Non projector headlights $200
1 x passenger window switch $50
Air con box $50
Heater box $50
Passenger window reg $70
Passenger and driver kick panel $20 each
Boost sender/sensor R32 $20
Clutch pedal $70
Break pedal $30
Carbon canister $20
Boot lid $70
Bonnet latch and cable $40
Fuel/boot cable $50
1 x stock r32 steering wheels ok condition $50
Surround ash tray $10
Front LCAs $120 a pair
Fuel pump $40
Dash all good vents small bubble on front $150
Door shells $100
2xcluster surrounds $20 with some cuts in them
Light switches/wiper switches $30 each
Carpet $100
Gear boot $10
Hand brake boot $10
Driver side dash vent $40
Sun visors $10 each
Rear view mirrors $20 each
Clutch master $30
Gear boot plastic surround $30
Indicators with wiring no outer covers $10
Wiper arms $10
Driver dash vent $40
Stereo brackets $20
2x driver side window switches $70 each
16” rays 2/3 piece $200 with good tires
Are the clusters from a gtr? Chasing one for my rb s13 conversion. Prefer grey with the needle stop at 9 o'clock. Pm me or text 0419 856 391
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
