I reckon the easiest way is to pop the pin from the relevant wire out of the plug and elec tape it to the loom . It doesn't take much longer and is reversible , not that you'd want to but why butcher something if doing it this way is so easy ?
A .
It's actually a little harder :)
I started with a small screw driver than just gave up so side cutters and headshrinks came out
Hey guys i just removed my hicas n put in the lockout bar and the HICAS light was on, so i cut that green wire and now i got no power steering?? has anyone else had this problem?? Oh and it come out of a r34 gtt...
you sure you cut the right pin? please use the schematic I posted on the first page
  • 3 months later...
Sorry for the bump
Ive just removed the entire hicas system in my track car.
I didn't realize that power steering could be an issue.
Ive removef the entire hicas system including ecu and all the wiring back up the car.
Am I going to have issues???
  • 3 weeks later...
The power steer resivour dipstick has a magnetic reed switch in it,
the float on dipstick has the magnet, and reed switch is inside the dipstick.
Reed switch inside the dipstick can fail, I repaired mine a few yrs back.
If your switch has failed. the switch has a inline plug, unplug it, if light goes out then you have found the problem,
the switch is faulty
Jaycar had a new reed switch for $2 I pulled the wires with gromet intact out of dipstick paying close attention to correct height. took a solder iron to it and replaced reed.
easy and cheap fix.
solution = light went out.
cheers
Edited by nobby
  • 1 month later...
Guys, just a little addition for those wanting to remove the pin from the loom plug rather than cutting the wire.
After about 15 mins trying to push the pin out, noticed there was this grey cover on the plug. If you lift that up you can get to the latch which holds the pin in. I just used a tiny flat head screwdriver to lift up the latch thingy while pulling on the wire. This was on a Series 1 R33 Gtst, but hopefully is much the same for others.
Thanks Johnny for this wiring tip. Got it sorted today after lock bar install, and no more HICAS warning ;)
  • Like 1
  • 1 month later...
I just got all the hicas pulled out of my car,R32 gtr 1990 model and the mechanic said pull the globe out.Was checking out this post thats says pin 15 but my workshop manual says pin20 feeds the warning light,so maybe R32s are different???Anyone else here done it to this model?
Where in the boot is the hicas Ecu on an r34?
I believe if you open the boot, squat down, and look directly in.. You should see it.
It may be covered by a panel of felt/boot material, but yeah.
Edited by sleptema
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
