HI ALL
I'm putting up one of a kind 350z's in australia.
Its time to part with my pride and joy up for sale
for some else to enjoy with all the hard work has
already been done and save yourself spending
big dollars building up a car
nissan 2003 350z
v6 3.5 liter
Blue in colour
6 speed manual
the run down list
ENGINE
Hks cams (step 2)
Je pistons (8.5.1)
Carr rod bolts
Carillo rods (h beam)
Hks gaskets
Arp head n main
ACL race bearing
BC springs n retainers
nismo oil pump
New tensioners
New chain
All Machine work done and Balanced
PARTS
Hks T51R spl bb turbo
Hks 60mm waste gate (screamer)
Custom made to suit DCS twin plate clutch
Nismo bigger pilot ball (clutch fork)
Braided clutch line
Custom made manifold
Hks twin power
HKS profected b2 boost controller
Proboost bov
Koyo rad radiator twin core
Blue radiator hose kit
Custom made over flow tank
Custom cut and flipped intake (sprayed wrinkle black)
Custom intercooler piping polished
K.L.S 600x300x80 intercooler
X2 spal 12inch thermo fans 1 pull 1 push
400ltr intake walbro pump (e85)
AAM full return fuel system
(all Teflon lines)
Denso 660cc injectors
trust oil cooler kit
vacuum lines are all 5/6mm turbosmart (Blue)
Every line/pipe in the engine bay is braided line with fitting
Oil Catch can
HALTECH 350z plug and play computer
Full chromoly cusco roll cage (blue)
With omp padding
Opm steering wheel
Strut bar
Carnot fibre engine cover
Carbon fibre rad cooling panel
Nismo 2 way (3.5's)
Starter motor relocated to the right side
All mod plated
EXTERIOR
Full genuine vertex body kit
Work wheels vs-xx
20x9.5+6 235/35/20
20x10.5-0 245/35/20
(only 2 sets in aus)
Rear LED Japan 350z Lights from the 07
Carbon fibre Garnish on Door pillar
Carbon fibre Garnish on mirror pillar
Carbon fibre aerial
Carbon fibre intake duct (front bar)
Carbon fibre roof lip
Carbon fibre vinyl roof
5000k low/high beam HID lights
SUSPENSION
tanabe gf sustec pro adjustables
spc camber arms
spc toe bolts
EXHAUST
custom made 3.5 to 3 inch dump pipe
to cat
fujitsubo legalis r cat back
INTERIOR
z floor mats and in boot mat
nismo gt shift knob
z aluminum sides teps
defi boost gauge
tinted windows
STEREO
pioneer 6.5inch tv/dvd/cd/mp3 player
alpine amp
pioneer front 6inch splits
pioneer 10inch subwoofer
I may have for gotten a few things
The car is getting tuned very soon so cant give you what power it makes yet but should be between 500/600hp
96% of parts are brand and have less then 3000ks car is also set up to run pump e85 fuel only thing holding it back is the injectors
Work on this car has always been done by 101 Motorsport
The car will come with a few spare parts
Standard body kit
Standard wheels
Standard steering wheel
Couple of other things
Car does not have aircon
And doesn't come with number plates
comes with rego and roady qld
Car has always be garaged and looked after
Price $46 000 ono
$50 000 swap r34gtr,chev impala ect
reason for selling is for a house deposit
Brisbane based
i dont come on here often so if need to get in touch me (ross) my number is 0401567736
thanks
https://www.sau.com.au/forums/topic/428689-built-350z-hks-t51r-take-a-look/
  • 1 month later...
if been wanting to do a turbo 350z since they came out!
This is exactly what i have.
I wish i had a 34gtr instead of a 33gtr as i believe i probably would've done the swap.
Anyway, your car is dope bro, good luck with the sale!
Ill just keep putting those $$$ away..
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
