HI ALL
I'm putting up one of a kind 350z's in australia.
Its time to part with my pride and joy up for sale
for some else to enjoy with all the hard work has
already been done and save yourself spending
big dollars building up a car
nissan 2003 350z
v6 3.5 liter
Blue in colour
6 speed manual
the run down list
ENGINE
Hks cams (step 2)
Je pistons (8.5.1)
Carr rod bolts
Carillo rods (h beam)
Hks gaskets
Arp head n main
ACL race bearing
BC springs n retainers
nismo oil pump
New tensioners
New chain
All Machine work done and Balanced
PARTS
Hks T51R spl bb turbo
Hks 60mm waste gate (screamer)
Custom made to suit DCS twin plate clutch
Nismo bigger pilot ball (clutch fork)
Braided clutch line
Custom made manifold
Hks twin power
HKS profected b2 boost controller
Proboost bov
Koyo rad radiator twin core
Blue radiator hose kit
Custom made over flow tank
Custom cut and flipped intake (sprayed wrinkle black)
Custom intercooler piping polished
K.L.S 600x300x80 intercooler
X2 spal 12inch thermo fans 1 pull 1 push
400ltr intake walbro pump (e85)
AAM full return fuel system
(all Teflon lines)
Denso 660cc injectors
trust oil cooler kit
vacuum lines are all 5/6mm turbosmart (Blue)
Every line/pipe in the engine bay is braided line with fitting
Oil Catch can
HALTECH 350z plug and play computer
Full chromoly cusco roll cage (blue)
With omp padding
Opm steering wheel
Strut bar
Carnot fibre engine cover
Carbon fibre rad cooling panel
Nismo 2 way (3.5's)
Starter motor relocated to the right side
All mod plated
EXTERIOR
Full genuine vertex body kit
Work wheels vs-xx
20x9.5+6 235/35/20
20x10.5-0 245/35/20
(only 2 sets in aus)
Rear LED Japan 350z Lights from the 07
Carbon fibre Garnish on Door pillar
Carbon fibre Garnish on mirror pillar
Carbon fibre aerial
Carbon fibre intake duct (front bar)
Carbon fibre roof lip
Carbon fibre vinyl roof
5000k low/high beam HID lights
SUSPENSION
tanabe gf sustec pro adjustables
spc camber arms
spc toe bolts
EXHAUST
custom made 3.5 to 3 inch dump pipe
to cat
fujitsubo legalis r cat back
INTERIOR
z floor mats and in boot mat
nismo gt shift knob
z aluminum sides teps
defi boost gauge
tinted windows
STEREO
pioneer 6.5inch tv/dvd/cd/mp3 player
alpine amp
pioneer front 6inch splits
pioneer 10inch subwoofer
I may have for gotten a few things
The car is getting tuned very soon so cant give you what power it makes yet but should be between 500/600hp
96% of parts are brand and have less then 3000ks car is also set up to run pump e85 fuel only thing holding it back is the injectors
Work on this car has always been done by 101 Motorsport
The car will come with a few spare parts
Standard body kit
Standard wheels
Standard steering wheel
Couple of other things
Car does not have aircon
And doesn't come with number plates
comes with rego and roady qld
Car has always be garaged and looked after
Price $46 000 ono
$50 000 swap r34gtr,chev impala ect
reason for selling is for a house deposit
Brisbane based
i dont come on here often so if need to get in touch me (ross) my number is 0401567736
thanks
https://www.sau.com.au/forums/topic/428689-built-350z-hks-t51r-take-a-look/
  • 1 month later...
if been wanting to do a turbo 350z since they came out!
This is exactly what i have.
I wish i had a 34gtr instead of a 33gtr as i believe i probably would've done the swap.
Anyway, your car is dope bro, good luck with the sale!
Ill just keep putting those $$$ away..
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
    • ..could be worse... but out here, renting private affords some luxuries ...we've even been told the Sept dateline isn't critical, and I'd rather move stuff in the cool of winter, than slogging it out in the heat. Recall we were talking about the million dollar view this place has?...that's what he got for it... (won't be so nice when the quarry happens at the back in the future...lol..)... ...cool, I'll stick the wiper motor in a wee box...umm.... the pinny is GLX trim ~ I think that's about as close as it gets to Silo spec when it comes to the S2 pinny...ie; electric mirrors etc etc...dunno about the trip computer/wiring...I do electronics repair, I'd be willing to take a look at it for you. As you saw, all the dash is there in that car..and thinking about it, it'd be easier to pull the whole center section out, rather than just the ashtray and rails, but your call...
    • The "sacrifice of low end" is now basically irrelevant in 2025. Turbo/ecu/fabrication/and other tech advancements gives a vast array of options to mitigated any of it. My setup now is a fantastic example of this. 300whp / 20psi @ 3500rpm from a 600hp turbo setup on a notoriety low reading Dyno Dynamics roller dyno, is almost unmatched on all of SAU and other forums. The only other turbo i've seen that can achieve this is a BW EFR + twin scroll / twin gates etc etc etc... ps. tuned by Matty Spry at P.I.T.S as far as getting to the 600 figure, while enlarging your itb's alone probably won't get you there, as Sucram has stated above, it will certainly help. Just do it Predator1 my brother hahaha 🙂
    • I use Taaarks/efi solutions ones. Years, and no issues.
    • At the Botany heavy vehicle inspection centre. At the time there were only 2 locations that did IM240 testing for free, the other location was at Penrith. I did a quick google, seems like the Botany and Penrith inspection centre is closed now though About an hour of my time.  At the time you could. They are closed now   No it was Government run, the site was attached to the RTA from memory. The guys running it at the time were awesome, if you didn't pass the test, they handed you the results and said make changes to your car/tune and have another go later. You drove in registered, failed, and drove out registered.   Obviously though if you were defected, sent there, failed. You remained unregistered.  From my 5 minutes of research (have a look at the date on my test results) looks like things have changed. So, I can't see any way to get this test done for free now Seems like you'll need to call around the engineering places doing the Vehicle Safety Compliance Certification Scheme or call around workshops with a dyno and try and get a RG240 test. No idea how expensive that is though or how easy it is to find a place offering it.  Bit depressing learning about this now. The first car I had engineered in NSW cost me about $250 all up.... So kids these days can't buy houses, looks like getting your car legal and engineered in NSW is another thing on the list of things they can't afford. Great.
