Sorry bout the late update so timing and everything's was fine.
Put it back on the Dyno with a bit more boost and at 18 pound it made 518whp.
So now changing it to e85 and upgrading the supporting fuel mods.
Hopefully can create a log of my journey from unleaded to e85 (flex fuel)
Wow! What setup are you running :O
Well far from where we want to be but basically fully built bottom end and all try e85 with the current t04s set up and new injectors pump etc and see what it makes with maybe 20/25 pound but want to try a bigger turbo lol
Im having a hard time understanding how the VCT could change the timing enough to cause your results to be that bad?
Yea I completely understand what us mean cause I'm still having a hard time with that causing the issues as well.
But no word of a lie only thing replaced is that and it idles fires no missing. Very odd
It appears that way. The only thing I noticed that was different after a lot of thinking was I couldn't hear the clicking from noise that the vct made when revving past the engagement point.
So that's basically how I found it.
But yes I think your rights jut kept it locked or in the wrong position
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
