Hi guys, if this has been covered, i cant find it.....
Basically I'm looking to replace my very smelly pushlock lines for teflon -6, on the surge tank and fuel pump is no problem, but what have people done to connect teflon to the stock tank with plastic barbs in a smaller size.
Car is R32 GTR.
That was what I was thinking, but its a bulky and kind of half ass way of doing it. I figure there must be plenty of people that have run teflon now on a skyline that may have a good suggestion.
To do it properly I most likely need to remove the intank section and replace the plastic with alloy lines, epoxy them in or similar.......
The way I have seen it done is to remove the plastic fittings and from the lid, and replace them with Speedflow bulkhead fittings or similar. I assume by cutting or drilling the plastic fittings out, and then using suitable sized fittings to replace them. Unsure how they are sealed in as I'm not sure exactly which Speedflow fittings were used.
I'm pretty sure this is how 34GeeTeeTee has done his, as JEM said his plastic fittings on his lid were actually a restriction. I'm sure he can confirm exactly what was done.
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
