Hey guys,
I really want to run a forward facing (not even for the performance gain, but for the fact that changing plugs and setting timing become a harder task with the piping running it's current course).
Just wondering who has used what plenum? and a link to purchase.
Pro's and cons of said plenum?
What you've had to move in the engine bay to run the plenum?
Have you had to modify the plenum itself to fit?
If the throttle cable didn't reach, which cable did you use?
Did the tps wiring reach or did it need extending?
Any other valuable information is appreciated.
Cheers, Cameron.
https://www.sau.com.au/forums/topic/428716-rb20det-forward-facing-plenum/
I agree with the comment above... in most cases going for a front facing plenum is going to be a performance loss, not a gain. This is due to the shorter runner length robbing you of torque low in the rev range. Due to the smaller capacity this will be very apparent with the RB20 engine and make it a pig for day to day driving.
You can get cheap copies of the Plazmaman style plenum top on eBay, this will retain your lower runners which is probably the best compromise.
http://www.ebay.com.au/itm/All-New-POLISHED-Nissan-R32-Skyline-RB20DET-RB20-GTS-Intake-Manifold-Plenum-/121040978566?pt=AU_Car_Parts_Accessories&hash=item1c2e9ac286
Keep the stock one, unless you just want your bay to look 'neater'
I was going to get the plazmaman rb20 plenum, but after reading a lot of info about these going onto rb20det it's a loss in power.
Also supposably it bolts straight on BUT other things will get in the way, battery ect.
So I'm sticking with stock, good for 270kw or more. An rb20 probably won't see much more than that anyway..
This was one of the plenums that caught my eye as it looks relatively standard to someone (ie: a cop) who doesn't know much about plenums and would only be looking for shiny chrome.
Anyone on here used it and has some feedback?
I simply wouldn't do this to any RB engine unless I was putting a high mount turbo on and there was simply no hope of keeping the inlet pipe running across the engine toward the turbo. All other reasons (appearance, accessibility of coils/plugs) are insufficient for the compromises and arse pain involved.
I have a t04e high mount using a stock plenum.. Still not changing though.. :) ..the plenum that is.
My t04e can get farrrrked
Edited by Zrobe
The use of the word "and" in my post is required to understand the meaning of it. The necessary conditions would be highmount AND inability to keep the crossover pipe clear.
lol relax man
I've actually ordered a plazmaman plenum for mine to simply clean up the engine bay and make everything easier to get to, I'm just waiting for it to turn up. So far I'll have to extend the tps wires and I'm not too sure what I'm going to do with the coolant pipes yet but I'll let you know how I go.
Just do it like the pic that johnnilicte posted. All the money you will spend on this could go to another turbo, or tune, or injectors, or guages or anything else you want. You will spend the money then regret it like i did on my RB25 when i bought a china front mount and all i had was issues, and for what? Nothing.
That's definitely going to be plan B, but it's only solving one problem..
I'm still going to do more research until I can completely rule out a forward facing, then I will retreat to Plan B.
I make money to spend it, and it's not really that much. I see it as more of a gain than a waste so I'm happy to justify a few hundred on a new plenum if it makes my life easier down the track.
Also, I don't want another turbo or any other mods to this engine along those lines. I'm keeping the car the way it is (to a certain extent) so I can enter it in the AS class for nationals and still have a car that's happy to be street driven. My extra cash goes into the track car which is where I want the power.
It's not a gain. It is a waste. And no, there are no options for bolting anything onto the standard runners that are as good as the standard plenum. Those options are only the least worst.
Big FFPs are for motors making massive power that need a big increase in plenum volume (and a suitable increase in TB size and so on). There's no need at all at anything up to quite unstreetable power levels.
Edited by GTSBoy
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 馃槑
    • Cool, I鈥檓 just down Sydney today. Not much time to get online.
