Hi all,
I know there is plenty of info on the outputs of specific turbos and combos of all sorts on here, and about every upgrade imaginable, but I have a slightly different question, I have a garrett t04z on my 25 thats been going well for many years, im making 360rwkw on 98 vortex with about 450cc/min of water meth, all this on stock cams too.
I know the t04z is a very old designed and somewhat laggy turbo, and on my setup its making 22psi at 5000 revs, with a 1.05 exhaust housing.
My questions are, should I look at a new turbo? Something like a gtx3076r for my power levels?
Im quite happy with 360kw and not very interested in much more. I can still almost double the meth im running for more power, plus cams would get more again, I see the 3076 making mid 300's easily but I want the room for 400kw, mainly for if I ever go e85.
Or is my most economical option putting a .83 rear on and keeping my current turbo?
Is it going to make it come on at 4k?
Is there an option that will make 400kw and come on by under 4?
I really dont mind the lag that much, but feel I could be doing better easier.
And finally fitment, will any of my options fit straight on where the t04z sits, in regards to the manifold, v-band 3 inch dump, and 4 inch inlet? I realise things will need modifying, just need to know what im in for.
Just looking for options, as I may do something in the near future if I see it being worth it, and what others recommend.
Hoping iv given all the info required. Thanks
Better can definitely be had for your particular setup.
A Precision 6262 CEA should be available in a housing config similar to your T04Z which will improve spool and add power. That is a first suggestion without major outlay which will improve power and spool.
If you want to stay sub 400kw but want the best of the best for a reasonable 'swap over' an FP 3582 HTA will probably be for you. A 3586 HTA is likely to be an awesome compromise if you want way more power, it will probably stretch out to mid 400s rather than the mid 3s mentioned though lol as will a 6262 CEA.
That should tell you what you want to know.
Thanks for the input, how are the hta for reliability? Im not going to head for mid 400's, maybe 400 absolute tops. Im pretty sure its just a t4 discopotato03
And whats more preferable in regards to HTA and precision?
And is the difference going to be where I notice a huge difference?
The HTA is just a modified Garrett so reliability is on your side... The only downside to these turbos is the cost, other than that they are a damn good choice for RBs
Precision are cheaper and will also get the job done well, have read a couple of reliability things BUT never seen any first hand so it could just be haters online :P
On E85 there is usually a 40kws of gain, if the tuner knows what he's doing.
On E85. Unless you put some cams in it. Or using factory cams:
A GT30 based turbocharger can not make over 400rwkws
A GT35 based turbocharger make get over 400rwkws, but can not make 24psi (minimum requirement to reach 400rwkws) any where near 4000rpms.
You will need our Alpha turbo systems to do this. And trailing result of 407rwkws with 24psi by 3700rpms using factory cams and E85.
You could go close enough!
I found Pump 98 is tinny bit more responsive, probably due to the extra heat:
Boost response. 98 (Purple) V E85
http://www.hypergearturbos.com/images/dynosheets/atr43/atr43ss2/290612/e85boost.jpg
I found the same thing Stao, perhaps the extra carbon content in the exhaust stream?
A GTX3076 would almost get you 400kw, (with a large AR rear) but not with the response of the Hypergear, or the HTA from the few results I have seen. e85 would be a must at that boost though.
The 2 HTA3076 results are 391kw with restrictive exhaust and 396kw with small inadequate intercooler! Still both were pushed and both seemed to make similar power! Mine was done on E70 pump fuel and stock motor + Headgasket, the other with proper E85 and built engine i believe. 20psi @ 3700rpm.... Still i reckon you would need to push pretty hard to make the magic 400kw mark but tbh in the 34 it just wouldnt matter, it bursts into wheelspin if you mash the throttle and down low it feels SO good....
I STILL dont have my flex fuel dyno sheets :dry: but i believe pump 98 was in the 330kw region as it wasnt pushed to higher boost levels.
It would have to be because of temperature. Extra "carbon" in the exhaust is not a useful factor. Simplistically, E85 exhaust would have the larger volume. There are more molecules of exhaust gas per unit of power made (or per unit of air consumed) because there are two O atoms in each CO2 and only one O atom in each H2O. So fuels that produce more water produce more volume. But that's the volume when expressed simply in terms of number of molecules. If you jam another 100°C exhaust temperature then that would add up to a larger change in actual volume in the exhaust. Once you've done all the maths and worked out that with basically the same mass rate of exhaust flow (there would actually be slightly more mass rate with E85, but ignore that for the moment) travelling at a higher velocity (simply because it is hotter and takes up more room) the 98 exhaust has more momentum. And that's just looking at it simplistically. If you go fully thermodynamic in your consideration, then now you're looking at the ex manifold pressure as well, and so looking at the total energy available in the exhaust (and what fraction of it is available to extract across the turbine). The simplistic view is sufficient to explain what we see here though.
Edited by GTSBoy
True, he will need cams to get this sort of result. The 407rwkws that I've archived is on stock cams with lesser boost.
I don't know the exact wheel profile of the HTA item, how ever SS3's turbine wheel is larger then whats in the GT30s. It should pump more power on your setup.
A GT3582R HTA will get 24psi near 4000rpm - as with a Borg Warner EFR8374, and they have proven reliability.
You didn't make 407rwkw, you made 407kw @ hubs - it'd be interesting to see it if would crack 400kw on that boost with stock cams, as I don't think I have seen anyone else do that with an RB25 despite some using similar or larger turbos. Unless proven otherwise I am far from convinced that the reason you have make that extra power versus cars run on other dynos on that boost on stock cams should be attributed to the turbo itself.
Comparing turbine wheel sizes between different turbine designs to determine flow is folly as well - a Borg Warner 8375 has a ~75mm turbine wheel compared to a 68mm Garrett one yet they are very comparable in terms of flow. Doesn't mean it won't, but certainly doesn't guarantee it will.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
