As a warning.
This is what happens when you have a extra heavy duty single plate clutch with a standard flywheel (suspect it to be second hand) and a R32 GTR with big power during launches. Yes, we only warned him last week.
post-2671-0-71729200-1373957121_thumb.jpgpost-2671-0-07224200-1373957146_thumb.jpgpost-2671-0-44082300-1373957227_thumb.jpgpost-2671-0-22976100-1373957245_thumb.jpgpost-2671-0-99562000-1373957263_thumb.jpgpost-2671-0-40418000-1373957278_thumb.jpgpost-2671-0-17263400-1373957306_thumb.jpg
https://www.sau.com.au/forums/topic/428748-r32-gtr-clutch-flywheel-explosion/
Benm had similar experience, although worse as his flywheel exploded and did far more damage. I remember seeing pics of this R32 anyone have link to pics?
Yes the clutch exploded only, although the factory cast iron flywheel are dangerous for big hp and big launches, as they may flex or explode. One piece billet Chrome Molly are best if using a single plate or a 7 1/4 inch twin plate, like Tilton. Nismo, Extreme, OS Giken ect also are billet steel. I am pretty sure for 10 second or faster cars ANDRA require a billet flywheel as well as a 6mm scatter plate around the bell housing.
In my race car I have a custom Chrome Molly Nitrided flywheel to suit the 16mm bell housing adapter and a Tilton 7 1/4 Rally clutch, btw clutch and flywheel combined only weighs just over 9kg. I also run a anti heat anti scatter ex Nascar blanket, over the tunnel inside the car.
  • 3 months later...
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
