Just got back from Wakefield. R888 can choke on a big dick. Mine were old, so they took a while to get some heat in and come back to life, but I got juddering understeer, the got hot, and then wouldn't turn. I had nt01 on the rear which was better, as newer, but found they went off after 5 or 6 laps. May need to decrease pressure more.
End of the day, the semis were no faster than my federal RSR time.
Interesting!!
Might add, I can't drive for shit, and I pussehed out under brakes lots.
Also, semis are a lot more communicative v rsr, and I found myself catching oversteer better.
Well i will be in the same situation! Will try do a run on RSR too see how i handle that first ;)
Is anyone out there running the same comp tyre for sprints and hill climbs and if so are you just starting the pressures higher for hill climbs???
Yep. I used to run A032R and Toyo RA1 back when I was hillclimbing and sprinting. For hillclimbs you basically want to start with cold pressures set to what the tyre's hot pressure should be at sprints - depending on how much of a burnout you do, you might start the rears a pound or two lower.
old semis on the front and newer ones on the back was never going to be a recipe for success. Particularly in winter at Goulburn. Not really fair to compare them to a matched set of RSRs all round.
I was pretty critical of R888s when i had them, because they didn't seem to offer much grip. But they can produce good lap times if you are prepared to throw the car around. I was only a tenth faster at Lakeside when i changed to FZ201s. But the car felt much more planted on the Federals, and needed less steering angle almost everywhere.
People say the R888 seem to work well on light cars. I think its more that the really light cars tend to be less powerful. R888s don't like putting power down while exiting corners in my experience. A lighter less powerful car wouldn't really test them so much in that regard.
Edited by hrd-hr30
Yup, agree with you, when I cleaned them up this morning for storage, I also found the front left, the one I was having trouble with is 6 years old. Lol.
I'll try some re55s on the front next track day.
Wakefield wasn't actually cold yesterday, it was quite warm.
cool, thought that might be the case. Still bummed about the federals, have searched around and found a few other sites where people have found a difference in the new FZ 201's. at 365 per corner they would of been very affordable. That's life I guess. Kumho's still the hot favourite I think ATM, performance-dollar-life wise. Not much cheaper than z221's but life span is sounding better still.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
