Hi guys i come again with a problem, im looking at this Evo 5 on the weekend did the usual Registration and
History Check, Its a EVO V GSR and its registered as a 2010 WHITE MITSUBISHI LANCER CS SERIES SEDAN.
The details for the vehicle you entered are displayed below.
  • Date of manufacture: August 2010
  • Date first registered in NSW: October 2011
  • Tare weight: 1400 kg
  • Gross vehicle mass
My last R34 coupe was listed as a sedan didn't really think to much of it, but
this is an entirely different year, model. What the hell is going on, educate me pls.
Thanks.
https://www.sau.com.au/forums/topic/428753-why-is-this-evo-v-registered-wrong/
During the tech night at JLM, apparently they no longer go off the build date on the plate. All imports are now to be registered to the year that it was imported in.
So if you go and import a R34 today, the build year would be 2013 (sweet!). Judging by that, it was imported 3 years ago, would have sat in a yard for a few months, then to dealership for a few months before it was bought for the first time, in Australia.
Those who also attended the JLM tech night about importing, if I'm wrong, please correct.
I see, i think its stupidity and confusing but im guessing it would be to complicated/expensive for them to do it properly for imported cars, probally
just following a general template and cant be bothered modifying it for imports. I dont even know what a CS lancer is lol. On another note that seems
like a long wait between it being shipped here and then being sold, might have been months before they got around to compliance.
Edited by starwarz
No that's not correct, imported cars are registered as the year that they're built, not the year they're complied. Either there has been an epic stuff up at the RTA or that, dear friends, is a rebirth.
For a short time (about 10 years ago), there was a loophole in the import regs that allowed whole cars to be imported as wrecks then cars here could be re-shelled semi-legally, but I've only ever seen examples of these cars registered in Vic. The importer responsible clocked up fines somewhere in the six figures for what he did. The duped owners were allowed to keep their cars registered in Vic, but they can't be registered elsewhere.
I would be steering WELL clear.
Seriously hate buying cars, especially when i have to deal with stuff like this. Last thing
i want is a rebirth but how would they allow a rebirth to be registered ? i thought that was
illegal.
Edited by starwarz
I let the owner know my concerns, he has sent me via email copies of all the import, compliance and rego papers car seems very legit
considering most of these documents you would be hard pressed to come upon, seems to me its the incompetance on the side of the RTA thats caused this fuss.
All thats left is to inspect it and hopefully buy and get this car hunt over with.
Edited by starwarz
At least that sounds like you've made some progress as the reason behind that.
Hopefully smooth run from here.
Sounds ilke a rebirth more than anything, does it have an import sticker?
The car was imported by http://glamgroups.com.au/ i have the import approval letter
given to Glamgroups under the vehicle standards act 1989, which authorised the import of the
evo v the car and vin is on that letter and is signed, then i have the compliance work sheet etc.
The company seems like a legit business and is ISO certified (meaning they need to be audited
if they apply for contiuing ISO certifiction, the last thing a dodgy business does is seek ISO certification lol) ,
i will also be checking import stickers and the rest on saturday, but im sure so far this car is legit, its got the legal document.
Edited by starwarz
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
