Hi Guys
Up for sale is my R33 gtst series 2 1996 model project car 108900km on the clock
current modifications
just rebuilt the head completely
Superspark coil packs
just did timing belt service with crank seal and cam seals with gates racing belt
Whiteline swaybar front and back
strut brace front and back
Cusco tension rod brace
B piller brace in car
Nismo solid shift short shift
GTR spoiler carbon fiber
tinted windows
black wire alarm system
braded brake lines new disks and pads with complete brake overhall
3 inch stainless exhaust from turbo back
HDI GT2 front mount intercooler
turbo smart BOV
forward facing plenum
Tomei 264 cams int and ext
bride carbon style seats
New Rims tyres are 70% warn
Turbo Smart Eboost street boost controller only boosting at 6 psi at the moment as the car needs to be tuned
K&N POD filter with Hi Octane direct POD box
will come with walbro 255L fuel pump
probably forgot things but will add as i remember.
There is no dyno results as it needs a tune first
car gets serviced every 1000km for oil and filter Motul oil always used
gearbox and rear diff serviced every 2500 Motul oils always used
car runs great but idles high as it needs an ECU and tune would finish the car off myself but i have just started my own business and need to cut my overheads looking for $8000 happy to negotiate have original seats so i can re install them and take the bride seats out and not include the extras if you want to drop the price
i know photos are terrible i have more i can send you via email, if you want more photos pm me. Car is in Sydney NSW 0414188763
https://www.sau.com.au/forums/topic/428763-r33-gtst-series-2-for-sale-sydney/
  • 5 months later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
