Ok first post so i'll make this quick,
When welding or grub screwing the vct oil feed shut on the R33 head and making up an external oil feed for the vct, can i use an rb30 headgasket and put it together using the rb25 head bolts?
Then put it all back together then good to go?
My reason for asking is because in this guide he shows in the second or third photo a bit that has been welded on for seating the rb25 head gasket?
http://homepages.vodafone.co.nz/~lakewood/Skyline/R33_head.htm
Is there any benefits using the 25 gasket?
Also with running the motor in, is it best to drive it softly for 1000ks (or whatever is recommended) with mineral oil then dyno tune it or tow it and chuck it straight on the dyno?
If driving it for 1000ks i will be using all the stock bolt ons rather than the upgraded items
I am using an RB25 head gasket. Run it in on the dyno - no softly softly stuff (assuming tuner will not thrash it to death). Then dump oil and refill and drive normally watching oil pressure and temps and checking for leaks.
did you weld the block for more sealing surface in that coolant gallery or is it not as bad as it looks in that photo?
In regards to the break in procedure I've always believed in this guys procedure-
http://www.mototuneusa.com/break_in_secrets.htm
Makes a lot of sense to do it that way. Seems a little heavy handed but he's done a lot of research to show that it works.
Yep. Start, check for leaks. None? Sweet! Get on the dyno and load it up. Gave it back to me and went belting through the hills. 3rd and 4th gear pulls up hills to 6500 rpm. 3 days later at the last years nationals, Wakefield park and airport runs.
Basically gave it as much load as I could give it from as early as possible.
Last engine was run in very similar. Never breathed a drop of oil.
Running in as per Piggaz's post above has been the correct procedure for at least the last 30 - 40 years (on dyno or road) - anyone telling you to take it "softly" is way out of touch.
Anyone ever done this ^
Im going to be running one in soon the old 1000ks softly way but that kinda looks to me like i better have a spare 30 block just incase haha
go for an internal vct feed and use NEW rb25head bolts
I've heard mixed things about this method, mainly that it has the possibility of starving other components when the pressure is required for VCT? It sure would be a tidier method, anyone with experience on this have some input?
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
