R32, Gtst, Gtr, Rb20, 25, 26 Sr20 Parts Going Cheap This Week Only
Aftermarket Leather seats no rails $280 pair VGC
R32 boot trim GC $30 (sides plastic lips also have plastic trim clips)
R32 genuine nissan floor mat centre rear $10
RB20 engine mount brackets $20
RB20 power steering pump, A/C, and adjuster bracket $10ea
SR20 Rocker cover painted gloss red pearl $80
12" thermo fan VGC $20
R32 "SKYLINE" sil trims $20 pair
R32 Handbrake complete assy, VGC $40
R32 Number plate lights $10
R32 VGC Roof handle $10
R32 GTR Speedo Drive Cable VGC only used for 1000kms $100 (Purchased new $170)
RB26DETT manifolds and dump pipes standard $20 all four
RB20, 25, 26 G/box-Block spacer plate $40
R32 front guards vented, VGC very high quality from japan standard width $220
HKS super dragger exhaust cat back to suit r32, r33, r34 GC $200
RB20, 25, 26 Flywheel with clutch bolts, needs machining $40
RB20/25 turbo dump pipe std $10
R32 clutch master GC $60
R32 ecu plastic trim cover VGC $10
R32 GTR Diff gears 4.375 Crown wheel bolts and pinion VGC, $150
R32 L/H indicator, top clip broken otherwise GC excellent lens, $20, easily fixed
R32/33 GTR Power FC D-Jetro, currently not working, $150
R32/S13 Hicas Lock Bar brand new $60
R32 GTR Transfer shaft and tailshaft $80ea
RB20 valley cover $10
R32 bonnet stick with rubber bung $10
Alloy Air duct for front bar to brake cooling $20 will suit any car
Oil catch can $20 brand new
R32 clutch fan $15
SR20 clutch fan $15
brand new fire extinguisher $10
R32 gtr L/H/F axle $80
Sr20 manifold with Hyflow turbo good for 350hp, no play sideways but back and forward there is a bit, however with oil pressure runs fine, no leaks, holds pressure very well $100
Drift pod $10
RB20 'avg condition' R32 top timing cover $20
R32 window wipers front GC $60 pair
Window washer bag with pump $10
Genuine nissan factory flare from R32 GTR unused very rare, $40 (sits on ecu trim)
R32 GTST front horn support with horn $20
R32 Radiator top mounts $10
R32 GTST A/C unit cover plate $10
R32 GTST cluster 135xxx on the clock $20
Rb20 rear timing cover plate (behind cam gears) GC $10 (may fit 25,26)
R32 interior trim piece under drivers dash $15 GC
Power Fc hand controller excellent cond. barely used Fcc3 model suits all late model Pwr FC's $250
R32 GTR RB26DETT engine loom avg condition perfect working order $100
Oil cooler with relocater plate $140 speedflow fittings
R32 A/C system every single part in engine bay, pipes pump condenser bracket absolutely everything to replace $250
please txt or call johnny 0414596256
Prices negotiable, feel free to ask questions, further pictures on request, located gold coast & have some other parts also!
sold me coil-overs that he said were in good condition with genuine spanners. Once I got them there were no spanners and he said they weren't included. The collars were that seized 2 of them broke trying to un-seize them. Put them in and they are stuffed knock like crazy! the steering wheel he also noted was in good condition, got It and the stitching is coming away over the top of the wheel.
I wouldn't buy parts from him by believing his description, view in person.
  • 4 months later...
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
