Aftermarket Leather seats no rails $280 pair VGC
R32 boot trim GC $30 (sides plastic lips also have plastic trim clips)
R32 genuine nissan floor mat centre rear $10
RB20 engine mount brackets $20
RB20 power steering pump, A/C, and adjuster bracket $10ea
SR20 Rocker cover painted gloss red pearl $80
12" thermo fan VGC $20
R32 "SKYLINE" sil trims $20 pair
R32 Handbrake complete assy, VGC $40
R32 Number plate lights $10
R32 VGC Roof handle $10
R32 GTR Speedo Drive Cable VGC only used for 1000kms $100 (Purchased new $170)
RB26DETT manifolds and dump pipes standard $20 all four
RB20, 25, 26 G/box-Block spacer plate $40
R32 front guards vented, VGC very high quality from japan standard width $220
HKS super dragger exhaust cat back to suit r32, r33, r34 GC $200
RB20, 25, 26 Flywheel with clutch bolts, needs machining $40
RB20/25 turbo dump pipe std $10
R32 clutch master GC $60
R32 ecu plastic trim cover VGC $10
R32 GTR Diff gears 4.375 Crown wheel bolts and pinion VGC, $150
R32 L/H indicator, top clip broken otherwise GC excellent lens, $20, easily fixed
R32/33 GTR Power FC D-Jetro, currently not working, $150
R32/S13 Hicas Lock Bar brand new $60
R32 GTR Transfer shaft and tailshaft $80ea
RB20 valley cover $10
R32 bonnet stick with rubber bung $10
Alloy Air duct for front bar to brake cooling $20 will suit any car
Oil catch can $20 brand new
R32 clutch fan $15
SR20 clutch fan $15
brand new fire extinguisher $10
R32 gtr L/H/F axle $80
Sr20 manifold with Hyflow turbo good for 350hp, no play sideways but back and forward there is a bit, however with oil pressure runs fine, no leaks, holds pressure very well $100
Drift pod $10
RB20 'avg condition' R32 top timing cover $20
R32 window wipers front GC $60 pair
Window washer bag with pump $10
Genuine nissan factory flare from R32 GTR unused very rare, $40 (sits on ecu trim)
R32 GTST front horn support with horn $20
R32 Radiator top mounts $10
R32 GTST A/C unit cover plate $10
R32 GTST cluster 135xxx on the clock $20
Rb20 rear timing cover plate (behind cam gears) GC $10 (may fit 25,26)
R32 interior trim piece under drivers dash $15 GC
Power Fc hand controller excellent cond. barely used Fcc3 model suits all late model Pwr FC's $250
R32 GTR RB26DETT engine loom avg condition perfect working order $100
Oil cooler with relocater plate $140 speedflow fittings
R32 A/C system every single part in engine bay, pipes pump condenser bracket absolutely everything to replace $250
please txt or call johnny 0414596256
Prices negotiable, feel free to ask questions, further pictures on request, located gold coast & have some other parts also!
Rear cannon part of exhaust is sold, I have only the intermediate part which is from cat to rear cannon includes a muffler, and it is 3 inch
Also quick update! R32 GTR rear diff gears for sale are 4.11 ratio (factory gtr ratio) 37 tooth crown wheel and 9 tooth pinion
sold me coil-overs that he said were in good condition with genuine spanners. Once I got them there were no spanners and he said they weren't included. The collars were that seized 2 of them broke trying to un-seize them. Put them in and they are stuffed knock like crazy! the steering wheel he also noted was in good condition, got It and the stitching is coming away over the top of the wheel.
I wouldn't buy parts from him by believing his description, view in person.
  • 4 months later...
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
