Hey guys I am finishing of a 32 gtr circuit build and onto the simple task of mounting the external cable that turns off the battery isolator switch.
I thought it was easy enough as ive seen a couple mounted just under the rear edge of the bonnet drivers side near windscreen and A pillar. Only issue is its a very very tight fit to make a bracket up and squeeze between bonnet hinge and back edge of bonnet.
Has anyone got any suggestions on where to mount it and pics would be even more helpful. I've googled and found nothing so far.
Thanks
Mine's not a 32 and not likely considered a good install but I can tell you that in my S13 the isolater switch is in the engine bay where the old battery used to be (now in boot) and it has a steel cable that runs up the lip between quarter panel and engine bay and pops out under the corner of the bonnet near the windscreen on the driver side.
EDIT: Here's a pic of before it was all done as I don't have a current on on hand.
The red square is where the switch is, the cable runs under that lip up the guard. I think I have a heavy duty cable tie holding it in place in one spot. I've tested it numerous times and it works everytime.
I'm sure there will be neater installs than mine but it took 15mins and was done with off the shelf parts.
Edited by ActionDan
  • Like 1
The alternator is wired to the dead side of the switch. It cannot supply power to the engine when the switch is pulled.
I had that issue in my car on my first wiring attempt lol, pulled the switch and car kept running.
In that pic the alternator is down underneath the Throttle body so my wiring was short.
Edited by ActionDan
umm a bit late, but that's where mine is too, it is mounted on the scuttle panel thingy. I did not use a bracket it is just mounted straight on the plastic, and has survived 8 years of use so far (only ever gets pulled at scrutineering every now and then)
