Hi All,
The following gear was taken out of my gf's car almost 2 years ago when she sold it and has never been used since. It is all in excellent, near new condition and was rarely used.
Ideal for someone just starting out but wants something cheap and well cared for.
The following is for sale:
* Pioneer KEH-P8650 Tape/Tuner CD Controller
Don't have much info on it :D
4 x 45W Tuner + Tape player + Cd Controller
Remote Control
RRP when new was around $950. Paid $750
* Pioneer CDX-P1220S 12-CD Stacker
Suits above HU and quite a few newer ones
* Kicker Impulse 652xi Amp
Great little amp, excellent for fronts or single sub
rated power--- rms power @ 12v
65 watts per channel into 4ohm ( stereo)
95 watts per channel into 2ohm (stereo)
190 watts ( bridge/mono into 4ohm)
dynamic power @ 14v
90 watts per channel into 4ohm( stereo)
130 watts per channel into 2ohm (stereo)
260 watts (bridge/mono)into 4ohm)
special built in features
1-- high level inputs and low(line level inputs rca)
2--- variable gain control
3---built in 2 way crossover ( high pass/)-(low pass)
4--kicker eq ( variable bass and treble control)
* Kicker Competition 10" Subwoofer in carpeted box
Nice little sub, hardly any use, still looks new.
Professionally built box, carpeted, suit almost any car as box is quite small. Has amp bolted to back of it.
Size (IN., CM) : 10, 25.4
Impedance (OHMS) : 4
Maximum Amplifier Power (WATTS PEAK) : 250
Maximum Amplifier Power (WATTS RMS) : 125
Sensitivity (dB 1W/1M) : 87.7
Frequency Response (HZ) : 30-500
Mounting Depth (IN., CM) : 4-9/16, 11.6
Mounting Hole Diameter (IN., CM) : 9-5/32, 23.3
Min Rec Sealed Box Vol (CU. FT., LITERS) : 1.0, 28.3
Max Rec Sealed Box Vol (CU. FT., LITERS) : 2.4, 67.9
Min Rec Vented Box Vol (CU. FT., LITERS) : 1.25, 35.4
Max Rec Vented Box Vol (CU. FT., LITERS) : 1.75, 49.6
I know she paid around $1500 for it new, not sure what to ask for it, so please feel free to let me know what it's worth, I'll update this post as soon as I know what a reasonable price is.
All items in Melbourne. Happy to freight at buyer's expense.
I'll post pics up in the next few days. Until then, here are some pics I found on the net of the same models:
Pioneer KEH-P8650 HeadUnit
Pioneer CDX-P1220S 12 CD Changer
Kicker C10 Subwoofer
Please PM me with any questions or offers.
Kind Regards,
SXTACY
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
