so am i the only one who copped a pm from one of them....
I have a car from Edward Lees and the car was perfect , not only that it came with 2 years warranty
You are a dirty little FLEA that wants everything for nothing , whinging and whining , over a $15,000.00 car , that is almost 20 years old, you are crapping on as if you have bought a $100.000.00
Porsche or Aston Martin, get over your self!! you obnoxious little Pratt. That company has been in business for over 42 years. What does that tell you , MORON ??
If you want a perfect car buy a brand new one and pay the new price. What I see of Edward Lees is the car are real, they haven't been misrepresented. What you see is what you get.
When you purchase the car, It goes out the back and the 2 mechanics go right through the car and make sure it is perfect.
That was my experience. I did have a problem and I called them , they booked it in and found that the exhaust had a sustained a big hit. I didn't lie to them and bitch and whinge , and make out that it was like that when I took delivery , I told them that I ran over a clump of wood and remembered a loud bang.
They repaired it any way for me, So what the hell are you talking about? You FLEA , Did you try and get something for nothing ?
I can see your photo , straight out of the trailer park! Do you like Banjo music and your SISTER ?
Not good for business boys..
https://www.sau.com.au/forums/topic/428847-edward-lee/
I like Del Amitri and (which has banjos) and my sister is a lovely person; we get along fine.
What would they think of me? :woot:
Well he hasnt seen your photo BUT could slot you into that description if you send him one via PM! Its a new friend for all :woot:
https://www.sau.com.au/forums/topic/428847-edward-lee/#findComment-6932964
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
