Hi all,
I decided to sell my R32 Skyline.
I bought it in October last year (2012) with the idea of it being a project car.
With having a 2 year old child plus another one on the way I'm finding it harder and harder to find time to do anything and i wanting to make a return to 2 wheels which i gave up to buy this.
I reckon i've put 1500-2000 klms on it since I bought it.
Since i've had it I've done the RWC which required a new windscreen, front rotors pads and tyres.
I fitted a set of DBA slotted rotors with QFM brake pads which for a 20+ year old car, pulls up better than my wife's brand new SV6 Wagon on even my brother brand new FPV GS!!!!
I have since fitted a set of 18 inch rims but still have the original R34 GT rims i bought it with.
Have also fitted a HID head light kit which has made a massive improvement over the originals.
It has a few performance mods but needs to be tuned for them all to work to full potential. Have recently discovered that it has a chipped ECU.
This is pretty much the original advertisement on this webiste i've copied and pasted over with some of the original pictures. and some new ones since i've fitted the new rims
xterior
Looks wise its fairly standard, has the factory type m skirts, rear pods and I have recently sprayed and fitted a genuine Gtr front bar. Also have fitted a rear lip from viva garage which is fairly unique and in my opinion looks great. Currently rolling on r34 gt stock wheels all round with good rubber. The car sits approximately 1" lower than stock height on bilstein shocks, nice and stiff ride but not to stiff for daily driving (height is still very roadworthy).
Interior
The interior is nice and clean for an 89 model with no cracks or bubbles in the dash, only let down is a tiny rip on the drivers seat. Only interior mods are a boost gauge sneakily installed where the drivers air vent should be which I still have. Also the factory head unit has been replaced with an alpine head unit with an iphone/ipod cable neatly tucked away.
Engine mods
Most of the engine mods have been professionally fitted by the previous owner which include an r34 op6 turbo, nismo 555cc injectors, z32 afm, hks pod, blitz return flow intercooler, splitfire coilpacks, 3" turbo back exhaust currently with twin drift pipes at rear but I have 3" blitz rear muffler to make it quieter. The engine bay appears completely standard due to the return flow cooler and hks pod being mounted inside the shell of a standard airbox. Have had a hwy patrol officer look over and did not pick a single thing out.
The car runs fine and appears healthy but is in need a tune as it runs very rich and has alot more power potential.
estimating power figures at around 165rwkw at the moment.
Have recently done a little service which included and oil and filter change using motal 4100 and installed new ngk copper spark plugs. An oil change has been completed every 5000km's by me since I have owned the car.
bad points
-rear guards have had the lips rolled for bigger wheels
-slight weep of power steering fluid coming from hicas lines but doesn't drip has been like this since I have owned the car (will not be a roadworthy issue)
-small scratch on rear bumper (hardly noticable)
$8,500 ono
Can be viewed in Healesville
Call Trav on 0438-217-644
https://www.sau.com.au/forums/topic/428848-vic-1989-r32-gts-t/
  • 4 weeks later...
Hi guys,
sorry for the late reply's. For some reason it hasn't been notifying me when someone has posted.
selcuk - Sorry dude, not interested in swaps at all. I will be looking to get back onto two wheels eventually but i'm very very picky on my bikes. And i've had alot of mates buy jetski's and piss them off at a big loss 12 months later.
Jack_Sky - yeah the'yre perfect actually. I've just copied and pasted the original ad from here and added what i needed to.
dropped price to $7,750.00
  • 4 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
