Hey guys,
Just having a bit of a high fuel pressure problem after installing my new Walbro 460lph fuel pump, was hoping someone might be able to think of something I have done wrong here.
So to give you all the information, I have just replaced my old Walbro GSS-342 with a brand new genuine Walbro F90000262. Straight swap over really, just removed the old pump and installed the new one, had to modify the cradle a tiny bit to fit obviously, but nothing drastic, very simple stuff. The only thing I did differently was instead of using the stock wiring harness, I ran wires from the pump directly through the lid using Superben's idea:
post-107339-0-16369000-1373095582_thumb.
Then from there to the relay and earth point, all as per normal. I otherwise haven't touched anything, didn't touch the fuel pressure regulator or anything in the engine bay from when the car was last running. I am using a Sard FPR as well.
After finishing everything off, I primed the pump to check it was working and it seemed to be, got this:
998031_10151473575522541_1255224751_n.jp
Seemed all good, so I primed it a couple more times for good measure, checked the pressure was still at 43psi, and then started the engine. Everything sounded fine, didn't suspect any issues until I looked at the gauge:
This is just at idle, no throttle being applied. I checked everything over again, but for the life of me I can't figure out what I may have done to cause the fuel pressure to go out? Only thing I can think of is maybe having the lid/hoses off for a couple of days may have let air/something else in to upset the regulator? OR, perhaps there was an issue with my old fuel pump? I wouldn't have suspected so, it never surged or gave any trouble. Tuners never mentioned the car starving of fuel at all.
Any ideas? I would simply adjust the regulator again, but I'd like to know why the pressure has jumped up in the first place...
https://www.sau.com.au/forums/topic/428855-fuel-pressure-too-high/
  • Replies 51
There are the higher rated sard Type-R fuel regs but I couldn't see that being a problem at idle. The FPR doesn't actually feed any fuel back to the return it only really comes in play under boost as far as I understand. Really got me stumped trying to work out whats going on. When you prime the car does the pressure go to the correct 43 psi again now or does it jump the higher pressure?
Return line probably isnt big enough
Yeh? Standard return line... Surely not everyone using this pump has upgraded fuel lines?
Nah when priming it always goes to 43psi. It's only when the engine is running that it goes to 60psi.
Ah disregard my post I just read a little more to get a better understanding (haven't mucked around with aftermarket fuel regs yet) I'd have to agree that increasing the fuel return is likely cause couldn't be much else at idle coming into play
Do you have some spare fuel line lying around that you can run from the FPR outlet to a large container/bucket, then start the car and see if theres a different in fuel pressure. It's not the safest way to do it but will give you an answer as to wether it is the FPR or return line that is causing the issue.
Obviously be careful if you decide to do this because of fuel vapours and stuff, probably best to do it outside :)
But yeah if you use the largest size fuel line that will fit on the Reg then you should have no restriction there. I can't say I've ever heard the return line being a problem, but thats not to say it isnt the problem.
The return bypass hole in the reg is probably only 2mm in size so I don't think the return line size will matter much. Are you sure the reg is genuine? I assume all was well with it before the pump change?
Can you perhaps try fitting another reg? I run the relatively cheap SX reg with twin Walbros on e85, no issues here.
Unfortunately I don't have another reg I can try, or any fuel hose :/
I am pretty sure the reg is genuine, I bought it from a seller on here... Hmm, this is a bit trickier than I thought it would be :(
What voltage is present at the pump now, as apposed to before? Is the FPR adjustable?
Was 14v, haven't actually checked this time. I'll have to borrow a multimeter. The FPR is adjustable yeh. I was going to try to adjust the pressure, I just don't want to cover up any problems by doing so. It was all working fine with the old pump, so just want to be sure everything is ok.
I get around 62psi pressure before it reaches the fuel reg so it sounds like maybe the reg isnt doing its job and is just running full pressure straight as it comes out of the pump.
what does that mean? The reg creates pressure in the system before it, all the way back to the pump.
what injectors? i would not be too concerned unless its bouncing, its not uncommon to to run 60-80 base pressures depending on target boost and pump capabilities. ID recommend a base of 60-100psi depending on application. I generally run 60psi on bigger injectors ie 1000 and 2000cc.
Basically keep TOTAL pressure under the injectors limits.
ID725 - 8.5 bar, 123.5 psi.
ID850 - 7.0 bar, 101.5 psi.
ID1000 - 7.0 bar, 101.5 psi.
ID2000 - 9.0 bar, 130.5 psi.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
