I would say, on the basis that the tests you have done so far are likely to give the highest possible fuel pressure you will ever see (cold weather, cold fuel, brand new pump) that you could get away with setting it just barely higher than it runs naturally. So maybe 63 or 64 psi. I would say that you are dead unlikely to get any more than you already are, and even if you did it would only be 1 or 2 psi, which would hardly ruin anything for you (richer is safer anyway).
As long as the reg and the fuel pump can keep that pressure stable across your whole operating range you should be gold.
As to your question about whether the loop you have in your line is causing any restriction....I would suggest not. Unless the hose is quite severely closed down it will still not have anywhere near as much restriction as the reg itself.
  • Replies 51
.... wait for it.
My bet is that you have an air bubble between the fuel an gauge. Due to the orientation of your gauge.
Cheers
Justin
Which has only manifested itself as an issue now, after installing a bigger fuel pump? After running without issue for over a year on the old pump setup?
Air is more compressable then fluid, and would make the gauge read lower if anything. So that is not the problem
So restriction or FPR issue I say. I would pull the FPR off and just have a look at the ports and everything just in case theres something silly going on there
Might have found the issue! Pulled the regulator off last night and had a look at it, but couldn't see anything out of the ordinary. So then I had a look at the piece of return line that came off the regulator and looped around the fuel filter and spotted this:
There's some sort of restrictor in there. Makes me wonder where this hose came from, I never purchased any hose with a restrictor in it. In fact from memory I actually just reused the standard return line, though surely they don't have a restrictor in there? Amazes me that it didn't cause any problems until now. Anyway, haven't had a chance to check whether I can lower the fuel pressure now, will finish installing the ethanol sensor and put it all back together and report back!
Yeh, me too... Wondering if maybe this caused some of my power issues, but I don't think so. Tuners never mentioned fuel was a problem, and it wouldn't have affected response anyway. In any case, I'm sure it wasn't doing any good, so I'm glad to be rid of it!
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
