Hey guys I'm a newly owner of a r34 gtt skyline. It's fairly stock besides the pod filter, after market exhaust and boost controller. I'm looking to get more hp/kw on a tight budget, what are some cheap/effective upgrades I can do to it without cutting corners? When I got the boost controller out on the high performance mechanic said my car lacked pressure and to upgrade the fuel pump. Is this a wise upgrade? And roughly the hp ill gain? I have a lot of questions considering I'm new to the whole tuning process
https://www.sau.com.au/forums/topic/428873-r34-gtt-tune-up/
welcome to the forum mate
to answer your questions i guess it depends on what you want to achieve with the car in general. From what you have said im assuming you dont have a front mount so that would be a good cheap start. Also im assuming the zorst is a cat back so can add front/dump to the equation for some cheap power increases.
as for the fuel pump that isnt really going to improve power thus fuel pressure and ensure you have to the fuel in the rail for the car to use.
From there you start spending money on things like injectors/turbos/cams/cam gears/ECU and the list goes on
https://www.sau.com.au/forums/topic/428873-r34-gtt-tune-up/#findComment-6933784
Thanks for the reply and the welcome. I want to achieve a sustainable every day car while having abit more power in it. I was roughly going for somewhere around 250rwkw. For a front mount what type of kit would be suitable/available? Also where's a good place in the perth region to do all these mods?
https://www.sau.com.au/forums/topic/428873-r34-gtt-tune-up/#findComment-6933795
for the 250wkw mark you will need to do a turbo upgrade aswell as injectors/ecu (or a remap of standard) Have a look under the forced induction sub section on here there is a whole thread on RB25 stuff which will help you and as for a front mount there is an abundance of places to buy them of the net or a local workshop
link to the FI thread here http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
I havent been in WA for 7years now so im not sure who is still around tho all my work used to be done by hyperdrive (my car was well in excess of the 500whp mark back then) but they are great people and will be able to sus everything you need.
I would suggest dropping into the WA section aswell and seeing who is around these days in WA for your performance work/dyno etc
https://www.sau.com.au/forums/topic/428873-r34-gtt-tune-up/#findComment-6933809
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 馃槄 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 馃槀馃槀 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
