Yeah so... I don't quite own a skyline but the Nissan I own shares a lot of R33 GTR parts.
It's a 1988 Z31 300zx wide body
Converted to a VH45DE infinity V8
GT35 xr6 turbo
Link standalone
R33 GTR brakes
GTR 5 speed
N200 long nose 3.7 LSD diff
GTR bucket seats
Tube & fin IC
Runs on 6 pound of boost and creates approx 420rhp and the car only weighs around 1100kg
It's a pretty hairy ride.
Plans - Motor
Moving up to 550cc E85 compatible injectors
Custom fuel tank & app e85 compatable pump
Increasing the spark (havnt settled on how yet)
Custom log manifold
Possibly twin turboing...
Other loose ends
Move the fuse box and relays into the cabin
Shave the engine bay
Look into running 355/332 brake upgrade and bias valve
Pics to come
https://www.sau.com.au/forums/topic/428874-sleepers-z31-vh45-turbod-300zx/
welcome to the forum mate, keen to see some pics and more info on the car
as mick said 555cc will be on the low side for corn fuel! better of going 1000cc straight out and u never have to worry. Saying that on 420hp already you could easily throw another 10psi into that motor and make plenty on pump gas as it is
  • Like 1
Sounds like an awesome build. What are your plans with the car? Track or street?
As everyone else has said, got straight to 1000cc injectors. 550's will be too small if you plan to take it further.
Hurry up with the pics!
Cheers for the comments.
Car will be used mainly for track. I'd like to stick to pump but I'm worried about pinging and it's comp being 10.1:1 blowing a ring. I havnt been able to find someone or a build with a vh45 going more than 10-12psi so that's why I was leaning to e85.
And yeah wot doesn't Take long before I'm at the servo again lol
The 550cc's are enough for 600, currently I'm on 380's an only 91% duty cycle and without sequential injection (I think that's the right term...)
I simply can't fit 1000's in there... Clearance is an issue to the inlet manifold.
If I do go TT ill be making a ffim where I'll have all the room in the world but for now I'll max out what's there.
I'll see how it holds up on 10-12psi on 100 ron, then look into e85.
600-650 is the plan, anything more simply wont get to the ground.
Also looking into 18x10 18x11.5 rims.
Thanks guys. I'll try uploading a pic of it on boost.
It does sound nice!
Thanks Luke GTR, I don't know how that didn't come up when I searched it... Even on nico forum there isn't any details. Anyway I'll be buying them, now I have to find a set of better coil packs.
Then I should be able to use what I have to easily 5-550rhp :D
Um yes lol
Starter motor relocated to the other side and bell housing welded back up, adapter plate made, custom shifter, ditched the transfer case and made new mounts.
I can't take and not taking credit for the build, my mate built the car and I bought it off him.
First ever car I've bought not built... But it's been done extremely well.
Anyone know of a better coil pack that fits a 45?
And also will there be another bbk group buy???
    • RBF660 doesn't meet DOT5.1 as it is too thick. DOT5.1 has a very low viscosity requirement compared to DOT3 or 4. (Dot5.1 must be half as "thick" as DOT4)   It would also be a big indicator for anyone using that fluid in extremely cold weather to possibly look to swap for something in the DOT5.1 range.
    • Here is as close as we got to a direct comparison(3 vs 4inch exhaust), a tickle more boost, which I am sure was in part due to the exhaust.  Made 790 on more boost.
    • Next minute, carbon fibre boot 😂
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
