Trying to install a wide band into my auto 32 gtst and have run out of ideas on where to run the cabling form the sensor to the drive unit which is inside the cabin. I don't really want to drill holes in the floor or firewall. There is a rubber boot underneath the shifter for the linkage to the transmission, but this location doesn't appear to be suitable as it could foul the linkage. The other option is from the engine bay through the same route as the engine harness to the computer, there seems to be another rubber boot/ seal there which is proving difficult to guide the cabling through.
Interested to hear how others have routed their cabling into the cabin?
Cheers Mike.
https://www.sau.com.au/forums/topic/428940-wide-band-installation-help/
Pass it with the engine wiring. I use a coat hanger with the end bent back and wrapped in a little insulation tape (so it doesn't tear anything up too much) as a guide rod to poke through, then tape the wire(s) I need to drag through into the cabin onto the hanger and drag it in. I have used method that to pass through wiring for and air-fuel meter, a pyrometer, for the IC water spray, and so on.
  • Like 1
I ran a 20mm holesaw through the tunnel and installed a grommet. Otherwise the wiring was too short. The sensor needs to be down near the back of the box and mounted as close to vertically as possible.
I Fed the harness up through the Shifter hole around the boot/boot holder. Just had to bend the steel boot holder a tiny bit so it didnt squash the harness. No issues at all
The shifter is only a rod into the gearbox, so theres no linkages etc around there, if you run it smart then theres no issues.
i just close the wire on the door. run them for many years like this... works fine. i do this because back in the day i only had one wideband sensor and i would need to remove it from my own car and use it on other cars that i was tuning.
never once had an issue.
Over at a mate of mine who is a retired panel beater/ spray painter, he suggested I look on the firewall for pre-existing hole that has been blanked off. As soon as he said it a light switched on upstairs and I immediately thought of the spot where the clutch goes through, will report back when I'm finished. :)
This was exactly what I tried after sussed out where the shifter goes through the transmission tunnel. I managed to get the coat hanger wire through the first rubber grommet, but it seemed to snag on another seal or piece of foam behind the firewall, it was getting late so I gave up and came in hear to post.
I positioned the sensor about a meter back from the turbo and 200mm from the cat. Tech Edge suggests the sensor is positioned between 15 degrees from vertical and 10 degrees from horizontal...
http://wbo2.com/lsu/lsuinstal.pdf
Edited by Missileman
If you take the shifter out and the boots off its easy to run up into the cab that way, then just put it all back in taking care not to crush the cable
But Where you have run it is fine, Shouldn't have an issue, just a bit longer distance for it to travel.
Saw that, but it looked too small, the small plug end on the tech edge cable is about 18mm Ø
Run the actual sensor through the hole from the inside of the car, surely the sensor will fit through. MIne does.
If you want to use the same grommet just put a clean cut through the side of it fro the wires and when it goes back on the car it will close up nice.
Edited by HR32GTS 4DOOR
You know he has already run the wiring for the sensor right?
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
